April 21, 2018, 04:00:51 PM
by Amik
[Today at 03:10:07 PM]
by PNW
[Today at 01:10:39 PM]
[Today at 12:58:04 PM]
[Today at 11:46:18 AM]
[Today at 06:18:07 AM]
[Today at 06:14:00 AM]
[April 20, 2018, 11:58:46 PM]
[April 20, 2018, 11:50:47 PM]
[April 20, 2018, 11:05:33 PM]
[April 20, 2018, 11:01:36 PM]
[April 20, 2018, 10:45:40 PM]
[April 20, 2018, 10:38:07 PM]
[April 20, 2018, 09:09:58 PM]
[April 20, 2018, 12:59:48 PM]
[April 19, 2018, 10:28:30 PM]
Danr realizes the dream with a 30lb Chetco Bubble Chinook!
AOTY 2018
Sign up for 2018 AOTY now.
Entry Fee - $40 (profits going to Heroes on the Water)
Enter your AOTY Username:
*If you haven't already, make sure that you also sign up for an account on the
AOTY website.
Topic: How To: Painting a shark mouth on your bow  (Read 11978 times)
Yarjammer
  • Captain of the Titanic
  • Date Registered: May 2008
After the discussion a week or so ago about custom painting on our yaks, I decided to give it a go...  Here is a basic photo tutorial of how I went about doing it.
Before you start make sure you have the following available:
*Acetone/Toulene/Laquer Thinner
*Paint masking tape
*X-acto knife or equivalent
*Drop cloth
*Desired paint colors (I used Krylon Fusion paint for the red and Fascolor RC car body paint for the black)
*Spray clear coating
*3M/Scotch white tape for teeth (I would use the Fascolor paint in white if I had to do it again.)
*1" foam brush
*200 or 400 grit sandpaper
*lint-free cloth
« Last Edit: March 08, 2009, 02:45:14 PM by Yarjammer »
Yarjammer
« Last Edit: March 08, 2009, 02:45:46 PM by Yarjammer »
Yarjammer
Here is the basic process I went through:
1. Thoroughly clean the bow with the lacquer thinner and a lint free cloth
2. Wrap the rest of the yak with your drop cloth to protect it from any over spray
3. Begin masking of the bow in the general form that you want you mouth to look like
4. Use your X-acto knife to "clean" it up and smooth out the shape
5. Lightly sand the unmasked area with 200 or 400 grit sandpaper
6. Thouroughly clean the unmasked area again to remove any dust
7. Begin applying the background spray paint in multiple light coats (I used about 7)
8. Let stand for about an hour or so and remove the masking tape
9. Begin cutting the small teeth out of the white tape, leaving a tag end for application
10. Trim the tag ends off to follow the contour of the mouth.
11. Apply the tape over the rest of the mouth.  Make sure to minimize the overlap and do not smooth over the tape to much
12. Use the X-acto knife to cut out the remaining teeth
13. Remove the unneeded tape and smooth down on the teeth
14. Use the black paint and a small foam brush to outline the mouth and teeth.  Make sure to slightly overlap the white tape (this will help seal the tape
15. Let stand for about an hour or so
16. Begin applying the clear coat in multiple light coats (I used about 10)
17. Let cure for about a week.
I tested it last week with Yessnoo and it help up great after a day on the water.  It does chip a little bit, but you really have to try to do it.  I'm sure the results will be even better when the ambient air temp is higher.
« Last Edit: March 08, 2009, 02:49:47 PM by Yarjammer »
bad lattitude
Yeah, dude! Killer!
  • **Ron, Ro, and AMB, You brothers will be missed **
Nice work!
I wonder if vinyl print sticker from a sign shop would hold up to abuse better than paint?
Yarjammer,
Beautiful job! All you need now are the eyes!
bad lattitude
Nice work!
I picked up a quote from a guy that would make stickers for me. I'm not sure how he'd get it to fit the curves of the bow of the boat, but I guess that's why he's the pro.
I also asked how much to have him make up some pictures of my wife to stick up on the sides like the old aircraft pilots did.
  • VFW, Life Member at Large, since 1997
  • ADTA.org
damnn, bomber nose art on a yak..who would'a thunk it.... >:D
hey, Yar, now you gots to change the avatar pic!!
Sometimes there's not enough Prozac to make it through the day.....
Nice work Yar! Very nice and clean. A really good thing Yar did was to put his design in a place that takes little abuse. I think everything we try to stick on our yaks will get ripped/scraped off at some point but putting it in a place that takes little abuse will make it go a long way. Also doing a kick ass job like Yar doesn't hurt either! ;)
Yarjammer
Thanks guys!  I think the decal idea might work, but it would be cost prohibitive compared to the relatively low budget attempt I did unless you did a bulk purchase.  One additional step/option might be in order to make it more permanent and require zero touchup- using the headlight rockchip film in lieu of a clear coat.
I was nervous about the design being obscured while on the water, but yessnoo said it is almost completely visible and unsubmerged.  This is probably due more to the fact the aft end is loaded pretty heavily compared to the bow.
I know a few of you guys have been on the fence about doing it... now its your turn to take a leap of faith and join the Tigershark Yak Revolution!
'Yak Monkey
  • Piscis Venator
Very nice, Yarjammer, very nice indeed. Really nice write up as well!
I've considered pimpin' my yak out for a while, but I'm not sure I'm gonna keep it around forever and want to be able to sell it clean. I may apply some reflective vinyl striping for fun and safety. Here's an easy source linked up for any interested in where to get striping by the roll. (Sign Warehouse - Universal Pinstriping) Reflective striping can be put on nearly any smooth surface, so you could make your 'yak light up BIG in any low light condition.
I'm a sign guy.  If anybody has questions, just ask.  I can write it up and post on the subject if there is enough interest.  Yarjammer's approach is more practical than a pure vinyl graphic of this size, unless you want to take the time to learn the methods used in hand patterning, cutting and applying vinyl (which I'd be willing to share here.)
  If people concentrated on the really important things in life, there'd be a shortage of fishing poles. ~ Doug Larson
Cool. I think a lot of us would like to do it but the most prohibitive factor would be how much it would cost. I'm sure a sticker the size of Yar's spitfire mouth would take some coin.
'Yak Monkey
  • Piscis Venator
  Well, I'm in the biz (temporarily out on medical leave) and have connections, but I can tell you that it isn't hard to get your hands on scrap material of that size and various colors. If you can find a shop that isn't desperate for cash (the bigger the better), you could probably walk out with enough vinyl to do something similar for $40 or less, depending on the size.  It's the labor that is so costly. I'd have to say that at my work we wouldn't touch doing this kind of thing for less than $225, and that would have to be a very simple design. That buys you 2 1/2 hours and materials.  :'(  Unfortunately, there is no standard that would be useful for the kind of design we're looking at here. When I think of the waterline and exposed hull of the kayaks that I've seen, the variation is tremendous.  They end up being custom every time.  This is one of the reasons why Yarjammer's approach is so practical. He's created the original shape in place, on the finished surface, with traditional painting techniques. Good way to go.
  I guess I'll think about doing something that I can take photos of as I go along. I do have the time these days.  How much interest is there in learning to do this by hand using vinyl? (of course in a new thread...)
-edit-
  I called the shop and asked our painter about making paint stick to plastics.  He only had one answer for it. Akzo Nobel makes a line of paint called GripFlex that is used to custom color the interior of acrylic and polycarbonate illuminated sign faces.  It requires 8 to 12 coats sprayed very thin with only 5 minutes flash time between coats (depending on temp). I don't think it's worth all this work, but just more info for those interested.
« Last Edit: March 10, 2009, 04:44:19 PM by 'Yak Monkey »
Yarjammer
I would also recommend Parma 's FasKolor paint.  I use it for painting RC Car/Truck bodies.  I am fairly sure it shares the same properties as the Akzo Nobel and is actually available to mere mortals. YM, where do you buy this Akzo Nobel?  I can't find any place that actually sells it.
http://www.parmapse.com/fas1.html
'Yak Monkey
  • Piscis Venator
Lemme take a look.  I'll see what I can find for distributors.  Akzo Nobel is an industrial supplier, so they may not make any effort to establish retail sales.  I'll see what I can find out.
News at 11.
