October 05, 2026, 09:49:02 AM
Topic: Base Layers  (Read 2727 times)
revjcp
  • Don't judge me...
I am specifically wondering a out how heavy one should go. I've looked at cabelas heavyweight and polar weight MTD... At least I think that is what they call it. Anyone have that stuff and like it or not like it?  Looking for educated opinions.
Malibu Mini-X
Formers Rides...
OK Trident 13
I have a set of medium weight Polarmax shirt and pants and a set of the Polarmax fleece shirt and pants.  I bought them locally at Andy and Bax in PDX for about $17 per item.  I like the ability to layer.  Sometimes its one layer of the lightest.  Sometimes one layer of the heaviest.  Sometimes its both layers.  I usually wear them under poly sweat pants.  If it is raining, I will wear them under insulated sweats.  My legs get cold when the rain is beating down and the drysuit is wet all day.  On really cold days, I have worn everything mentioned and a thick fleece jacket under my dry suit.
If I was going to just buy one, I would go polar weight in the Cabela's stuff.   I like the stuff that has the fleece on both sides.
« Last Edit: March 16, 2013, 10:28:20 PM by craig »
Depends on what type of fishing you plan on going and how hot or cold your body runs. You can always layer lighter layers but you can't make a heavy layer lighter. If you are going to be paddling all day I go much lighter than if I plan on sitting on an anchor all day.
You can never have too many base layers. Mix and match to find what you like.
I like my heavy fleece bunny suit.  Sometimes I put heavy military surplus polypropylene over my bunny suit and under the dry suit.  But, I tend to run cold.
All my layers have a proper relief port.
The newer REI PolarTec sucks.
ohbryant
  • Date Registered: Jul 2010
Just got one of them bunny suits and I like it a lot but it will be too much for days in the 50 degrees + range.  Like they said layer on those cold days, you can always take some off or just be too hot, but too cold really sucks.
