October 05, 2026, 08:05:29 AM
Topic: Penn 321 gti...  (Read 3991 times)
revjcp
  • Don't judge me...
I just ended up with one of these paired with an ugly stick.  Good for halibut?
Malibu Mini-X
Formers Rides...
OK Trident 13
CraigVM62
Plenty of line capacity with braid.  Depending on what line weight your fishing with, it would just be a matter of what shape the drag is in.    I think the 321 stock has under 10 lbs of drag.  If using the rule of thumb of 25% drag setting to line weight, no problem fishing 40 lbs line.   Many experienced anglers see a reels drag limit determined by their thumb.   There is also a good bit of info around regarding beefing up the drag on Penn reels.
I have always used this method for setting up  lever drags.  Should work just the same to test a star drag to see what it is giving you.
« Last Edit: March 16, 2013, 11:52:42 PM by CraigVM62 »
10 pounds of drag is plenty. The 321 holds 400 yards of 50 pound braid. It will do just fine as a halibut reel if you like a left handed reel for deep water.
