November 03, 2026, 07:28:04 PM
Topic: Noob/lazy man mistake...  (Read 19150 times)
Drain you're kayak after fishing, especially if paddling freshwater and even if you think you're going out again the next day. Because if you don't end up going the next day...or the day after...or a few days later, you'll forget to drain it, and some sort of biohazard will eventually be found inside...
I've been fishing my Revo13 for about 3 years and have forgotten on occasion to open the hatches during storage and yet it has never created a bio-hazard inside.
What are you putting inside your yak?
good question......
-Rodney-
When catching fish, blood, plus water, plus bait, usually makes it's way into the hull.
SturgeonRod
  • Date Registered: Aug 2012
good question......
-Rodney-
sounds like a serious seal issue I would want to address immediately.
-Rodney-
-Rodney-
Usually happens when you catch a fish, then your hatch gets blood on it, then a little water, then you open it, and the stink drips in a bit at a time.  A limit later, you got all kinds of nasty inside the boat, specially if you're out bottom fishing.  "Oh hey, Cabezon #5 threw up all over my hatch while I was taking the hook out."
SturgeonRod
still sounds like a leak issue, I have never experienced this problem and I have harvested my fair share of yak fish.
-Rodney-
-Rodney-
-Rodney-
It's not.
micahgee
Don't open the hatch...problem solved  ;D
www.heroesonthewater.org
SturgeonRod
-Rodney-
It's not.
what kayak are you wielding?
-Rodney-
-Rodney-
SturgeonRod
well being a self bailing kayak one should rinse thoroughly before opening any hatch after harvesting or bait handling, if there is water getting in an in opened hatch it is called a "leak" lol and I would address it. If its from open/closing the hatch that's a different story ;)
-Rodney-
-Rodney-
It's a super minimal amount of water. Hatch is closed and you pull wet feet or fish on top of the hatch area. The water pools on the top of the seal. Open hatch again and it goes inside boat. Or even if it leaks slowly in it's NEVER going to impact the performance of the boat. I'm sure another point of entry is through the rudder lines when the stern buries in a swell. Again, minimal.
SturgeonRod
ah yes Ido get a tiny bit through the rudder lines and rear factory rod holders if raining. I have heard of using silicone spray for improving hatch seals. I will be using some on my hatches as soon as I remember to pick some up.
-Rodney-
-Rodney-
