November 24, 2026, 05:54:35 AM
Topic: Paddle??  (Read 3538 times)
KEELHAULED
  • Date Registered: Jan 2013
Do any of you Hobie PA owners or pro's have any recommendations' for the paddle length for a PA14?
The width of the Kayak (boat) is 38" (inches)
Any input would be useful.
Thanks
Rodney
BentRod
Rockaway Beach Oregon
-Jacques Cousteau
Try oars ....
KEELHAULED
Try oars ....
Sometimes it seems like it would be the best, but storing them would be the problem.
BentRod
-Jacques Cousteau
  • Date Registered: Oct 2009
My factory PA-14 paddle is 90" long.......I just use the t-handle in 1/2 the paddle....it's 48" long and works fine to get in or away from shore.
I store the unused half of paddle inside the hull through the front hatch just in case I ever need the "full paddle" length. :banjo:
90" is a 230 cm paddle.
FWIW, in an Old Town Predator at 33.5" wide, and sitting with the chair in the upper position, I found a 240cm to be better for me.  That's not as wide, nor do I think I'm sitting as high, as a PA.
240 is about as long as you can normally get, although I have seen some up 275's, especially for the NuCanoe's (Frontier 12 is 41" wide).  Those are Cannon Wave's.  They have a 15% upcharge for anything over 240.
If your primary propulsion is pedaling and you just need a paddle for backup, I'd get a 240, as they should be readily available.
I just use my Werner Skagit paddle when in my PA12 and it works just fine.  I think it's a 240.  The Hobie paddle that comes with it is plenty adequate too IMO since I'm never really paddling a considerable distance.
« Last Edit: July 28, 2013, 05:56:36 PM by rawkfish »
KEELHAULED
Thanks Allen;
I have yet to use the PA advantage chair in the full up position. I will probably try the 240. Thanks again
BentRod
-Jacques Cousteau
