September 13, 2026, 09:59:17 AM
Topic: Using your VHF  (Read 5650 times)
revjcp
  • Don't judge me...
Are you supposed to check in with the coast guard when you hit the water?  How do you know they are receiving you if you don't? Just looking for the right procedure.  Tia
Malibu Mini-X
Formers Rides...
OK Trident 13
If I'm going to be fishing a good distance from shore solo, I'll call for a radio check  on channel 16 when I 1st get out.  You don't generally get a response from the CG but other boaters will respond letting you know that your broadcast is being picked up.
Radio Check Example:
This is yellow fishing kayak outside Tillamook Bay requesting a radio check on channel 16.  This is yellow fishing kayak outside Tillamook Bay requesting a radio check on channel 16.
Example Reply:
Yellow kayak we read you loud and clear.
« Last Edit: September 15, 2013, 04:05:59 PM by Spot »
KEELHAULED
  • Date Registered: Jan 2013
Example Reply:
Spot is spot on  :). I will call for radio check and usually get a reply from C.C.
BentRod
Rockaway Beach Oregon
-Jacques Cousteau
