November 22, 2026, 06:20:21 PM
[Today at 05:32:50 PM]
Topic: Slick Strips group purchase  (Read 6800 times)
I meant in person.
I meant in person.
You can check and see if Demonick is bringing it to ORC?
Dom won't be at the ORC , is anyone else interested in joining in? We got 5 rolls so far. Would like to make the 25 mark.
windknot
If I read the details right each roll is 50' in length.  With two yaks I would only need 15' max.  Anyone interested in splitting a roll?
I'd split a roll, would only need 15' also.
I can use 15' too if you have that much left over.
... I'd like to see this installed on a Yak.
http://www.northwestkayakanglers.com/index.php?topic=13265.0
I used the same material, same thickness, but got a 12" wide strip and cut it down.  Works great.  It's really tough.  The 3" wide would probably be easier to work with.  I've only protected the keel and the nose.
« Last Edit: July 04, 2014, 09:04:43 AM by demonick »
We got 5 interested so $73.71 per roll if no one else wants to jump in. Those that have mentioned it please confirm you still want one. Still $8.00 per roll shipping to here then add shipping cost if need to get to you.
1. Jojopotato
2. DWB123
3. No oil needed
4. No oil needed
5. Firefly/indyflier
1. Jojo confirms 1 roll
« Last Edit: July 14, 2014, 08:29:32 AM by Mojo Jojo »
IslandHoppa
  • iHoppa
« Last Edit: July 16, 2014, 03:35:04 PM by IslandHoppa »
iHop
1. Jojopotato
2. DWB123
3. No oil needed
4. No oil needed
2. IslandHoppa
Let me know if your still interested or if you want to join the purchase.
DWB123
  • Date Registered: Aug 2013
What'll it end up being per unit per person, including shipping, etc...?
1. Jojopotato
2. DWB123
3. No oil needed
4. No oil needed
5. Firefly/(anyone want to go halfs with?)
« Last Edit: July 20, 2014, 11:03:00 PM by Mojo Jojo »
$81.71 for a 50 ft roll 3 inches wide plus shipping to you if you can't pick it up in person can probably work out somewhere in the Beaverton area for drop off. Any one wants to go halfs with someone $40.86 plus shipping.
