November 22, 2026, 03:07:01 PM
Topic: spooling braid direct to reel.  (Read 6652 times)
dampainter
new reel which has a smooth spool, i want as much braid as i can get so no mono backing....do i put a piece of electrical tape or duct tape or sporttape? ( to keep line from spinninng on spool later fishing?) first? then fill it up or tie and tape knot?
do i dunk spool of line in water to put on reel as tight as possible? or just fill it up with tension from my fingers as i am reeling up?
Mistah Yates
  • Date Registered: Jul 2012
I asked at Ted's.They say electricians tape on the spool as well as make sure line goes on tight.
I typically put a wrap or 2 or electrical tape on the spool and use my fingers or run the line through a phone book to keep it tight.
SteveHawk
I usually tie the line on tight over one wrap of electrical tape . I follow that with one wrap of electrical tape over the line. I figure that it locks it in place.  Extra insurance if you will.
I usually wrap the line twice around PVC pipe to place tension on the line as I spool it on.
Green Outback, Blue Revo
Just curious: since it only takes one or two wraps of mono around the spool - 6 to 10 feet at most - why is that an issue?
I usually put 20 or 30 yards of mono on a spool, even if it's brad-ready thinking that if I get spooled, I want a little springiness to protect the rod.  That's not a recommendation, that's just me being obsessive...
yaktastic
  • shut up and let me fish.
I use tape or put a few wraps on then tie it off.
4th place 2017 TBKD Rockfish.
no_oil_needed
Whatever tape you use, make sure it doesn't absorb water. There is no need to dunk the spool with braid.
Relax. You'll live longer.
Wow! A phone book, huh? I haven't got one in years. Can I just go to Whitepages.com on my laptop and run the braid through the closed laptop as a substitute?  8)
no_oil_needed
I'm sure you have a few Harry Potter books to use instead of phonebooks  >:D
Skidplate
I buy line when fisherman's has a sale. Cheaper, and most of their guys are able to pack it on perfectly. They normally use black tape, but I ask them to back it with mono or even Dacron to use up space on larger reels.
dampainter
ollie damons told me that when a machine puts line on that the reels gears are not meant to run or turn as fast as machine loads up line and can do damage. it`s why i put line on myself now.
 i ended up using one wrap of electrical tape, tied line, put small piece of tape on tie and reeled er up.
« Last Edit: February 15, 2015, 07:45:08 AM by dampainter »
I find that hard to believe as a total blanket statement. The most expensive reels get filled by machine and I have never heard of a reel being damaged.
dampainter
call ollie`s,  no reason they would not tell u same thing as they told me. they said if u do have them spooled at the stores that u ask them to do it slow. instead of doing that i`ll just spool my own and not take any chances. i never heard of reel getting damaged either til i took a reel in to ollies and they said damage was due to getting spooled too fast. i dunno, call ollie`s.
« Last Edit: February 16, 2015, 10:26:50 AM by dampainter »
islandson671
  • Heroes On The Water NWest
  • Date Registered: Jun 2010
I prefer medical tape
tambs
  • Date Registered: Aug 2014
