November 11, 2026, 10:57:06 PM
Topic: Crazy idea  (Read 14169 times)
beer2O
  • Date Registered: Jul 2014
I was just thinking about a pedal drive kayak replacement, which doesnt inhibit your movement through shallow water (like mirage and propel).
The idea:
A jet propulsion kayak which intakes water on one pedal stroke and then pushes it out on the other stroke moving you forward. Not sure how efficient it would be, but I can get a decent amount of force using a hand held bilge pump.
Just thought i would share that.
2015 Hobie Outback
2011 Hobie Revo 13
Wouldn't you want a bicycle-like pedaling system so the impeller was always turning?  It seems to me that a setup like you described would give you pulses.
I like the idea.
beer2O
A bicycle type drive would work better. Now if I had a couple hundred thousand for R&D I'd be golden.
2015 Hobie Outback
2011 Hobie Revo 13
  • Date Registered: Oct 2009
Interesting idea, but I wonder how many RPM  the pump needs for controllable  use?
beer2O
Could have multiple impellers which go into smaller diameter exhaust tubing which increases the force?  ???
2015 Hobie Outback
2011 Hobie Revo 13
beer2O
I have little to no expertise in hydro-propulsion/dynamics. Just thought it was a neat idear.
2015 Hobie Outback
2011 Hobie Revo 13
I also have no expertise in hydro-propulsion/dynamics.  But I was under the impression that jet boats use a lot more gas than motor boats with propellers, which suggests that jet propulsion systems are less efficient than propeller systems.  If jet propulsion systems were more efficient than propeller systems, I would expect that a much larger percentage of boats and ships would utilize jet propulsion systems rather than propeller systems.
Dan_E
  • Formerly known as Indyflyer
  • Date Registered: Dec 2010
Correct, I once had a jet pump on a PB and the rated HP was 30% less than the equivalent prop drive for the motor.
A couple of years ago there was some posts about a jet drive surfboard being developed somewhere in Cali.  I wonder whatever became of it?  Looked like it could be adaptable for kayaks at the time.
beer2O
They have these things, which look pretty sketchy.
2015 Hobie Outback
2011 Hobie Revo 13
Looks like a nice way to snap your neck.
yaktastic
  • shut up and let me fish.
Just put a turbo on it that will solve any propulsion problem  ;)
4th place 2017 TBKD Rockfish.
yaktastic
I just watched that! Holy crap.break through the surf in that sucker.tuna anyone?
  • Date Registered: Jan 2015
Never tried one of these but saw it several years ago and it looked "different".
http://www.streamdancer.com/kayakfishing.htm
Hey you first cowboy , hope you got some experience on Bulls or submarines cuz your either going high or under.
Mark Collett
  • Make It Happen
  I think that would be all kinds of fun. I can only imagine the possibilities. How cool.
  Definitely not "human powered". That would be some serious peddling.
  Wonder how well it'll troll down ???
  Time for a little research......
Life is short---live it tall.
