November 22, 2026, 04:57:15 AM
Topic: Undersized swivel  (Read 3834 times)
Kyle M
I'm getting this banana weight ready for chinook and questioned the strength of the leading swivel, so I grabbed the end with needle nosed pliers and pulled. It failed at about 15 lbs.  Definitely not enough for a big king.  I'm replacing the one on the other weight as well.  Whoever sets these up isn't thinking.  That first one wasn't defective, just undersized.
C_Run
I've got to go look at all mine now. I've got hand fulls of those. Thanks.
Merz
  • Date Registered: Sep 2010
 I have the some of the same weights from bimart. I just tested one the way you did, and it broke easily. I have some other brand weights the same size, and the swivel is much larger.
-Evan
1st 2016 AOTY
1st 2018 SBAOTD
1st 2019 BCS
1st 2022 SBAOTD
1st 2023 BCS
1st 2023 SBAOTD
This is a good lesson in trusting what you feel rather than what some company puts out on the shelf. If you think it looks like it won't hold up to a fight with a big fish, it probably won't. It's stuff like this that made me start tying all my own rigs using hooks, swivels, and split rings that I know will hold up. Attention to detail is an important component in consistently putting fish in your boat. Good on ya for trusting your gut feeling.
  • Chris
I guess I'll be the nay sayer, but I've used those things in a pinch while sturgeon fishing and they held up all day.  >:D
8th Place 2014 AOTD
1st Place 2013 AOTD
Sponsorship and Support:
Waxer's Surf Shop
Hobie Fishing Team
Lancer Jigs
Pro-Cure Scents
CraigVM62
Very good food for thought.    Looks like even the smaller 1oz weights use the same sized ball chain as the larger 6 oz versions I have.  I am thinking that seeing they can pick up a 25 lbs weight while being able to spin would be a good test.  Will use a fish scale that shows the peak weight so to know at what weight any of them failed at.
