November 11, 2026, 04:11:53 AM
Topic: Launching from whiskey gulch  (Read 4021 times)
Beachmaster90
  • Date Registered: Feb 2015
I'm thinking about launching there this weekend and I was wondering if a west wind or any other wind or swell direction can make it risky.
I've never been over there but I'm aching to get some halibut and Sunday looks doable. Anyone else headed out there that day?
Beachmaster90
Also how fast does the tide get ripping there?  I'm assuming it's only worth fishing around slack...
jmbx2ditto
  • Date Registered: Jun 2015
I'm headed there now if the weather's bad I'll fish Homer until it clears
jmbx2ditto
I'll give you a report when I get there.
WG is fairly easy.  You are protected from both the South and North.  West is bad but its such a short fetch, it usually doesn't create a problem.  Too many variable to say this is good or bad in general.  Take a look at a page I did for Cook Inlet: https://sites.google.com/site/kayakfishingalaska/locations/cook-inlet
What can happen is it be mirror calm on the water, but a large storm with south wind passed through a day or two before and you can residual swell.  This creates large swells that break on shore.  But once you get opoass those breakers, it is flat calm.  mightbe two three ft swells but super long periods so its not noticeable on thee water.
For Saturday, it looks like max current is about three MPH.  Here is the data from Navionics chart.  This is for a few miles off ANchor Point.
Here's the most recent forecast.  I think it looks do-able but once again, the water moving in different directions can always change it. l
« Last Edit: September 10, 2015, 09:52:25 AM by kardinal_84 »
Also when the wind is coming from the south or there are residual swells, I look here.  It's the buoy at the K-bay entrance.  This looks ok too
http://www.ndbc.noaa.gov/station_page.php?station=46108
Another useful site:
http://www.homerwebcams.com/
Update at 11am looks like a turn for the worse.  Spot forecast not shoing at the moment.  There is always a few hours lag between spot and regional forecast.
michilutiiq
  • Date Registered: Jun 2013
You guys camping down there? I'm 90% headed that way tomorrow as soon as I can sneak out of the office.
jmbx2ditto
It's getting your kayak past Turnagain arm that's the problem. Heavy winds they're trying to rip it off my rack
Akfishin
I'm camping down there when I get there... Late Friday it looks like.  Earliest I can bail is like 6
michilutiiq
I'll be around. With a silver truck and olive yak. And hopefully a big cooler of meat.
jmbx2ditto
WG rough when I got here. Right now looks good but there are storms off the distance. Enjoying the calm now, see how goes
It's supposed to come down overnight but pick back up again Fri night.  New spot forecast only calling 1-2 ft off anchor point Friday.   Should be do-able.
If I can drag myself out of bed at 2am. Hope to hit the low. Wishful thinking launch time is 7am.
michilutiiq
So you're waking up in 5 hours? Driving 4 hours...  You deserve your fish,  my friend.  I'll be putting in around 5 pm tomorrow if all holds to my plan (including the weather...)
SwansonSilver
Also to reiterate what Rudy has mentioned in previous "tutorials", the current will continue to move for at least an hour after the documented high or low. For example if the tide book says low at 0900, expect to be drifting south until around 1000.
-Ron Swanson
