November 22, 2026, 12:09:27 AM
Topic: 2015+ Hobie seat scupper assembly  (Read 6932 times)
Hobie is aware of this.
Its pretty straight forward to remove it. You can always put it back if you want. You just have to be careful not to damage the lugs on the threaded plugs. It takes a special tool, but I used a pair of snap ring pliars and that worked pretty good to get it loose enough to thread the rest of the way by hand.
That scupper is just too restricted for it to flow out very well with the small venturi, and definitely not when not moving. With your butt suspended in the Vantage CT seat it shouldn't get wet anyhow and just drain quickly if water does get in there. Now that's with my fat ass and all my gear in a Revo 11! Needless to say, I was displacing some water and have a bit of draft.
<Proverbs>
I was also thinking of custom shaping some foam to keep it from building up in quantity in the first place.
  • Chris
You should make a couple, and I'll buy one from you.
8th Place 2014 AOTD
1st Place 2013 AOTD
Sponsorship and Support:
Waxer's Surf Shop
Hobie Fishing Team
Lancer Jigs
Pro-Cure Scents
You'll want to also make sure there isn't anything stuck in that drain. It collects stuff pretty easily if you leave it open.  It really doesn't drain well once you get some stuff stuck in it.
