November 11, 2026, 03:17:01 AM
Topic: Attention Propel Owners!!! Inspect your drive uint!!!  (Read 8012 times)
I gots 5 inches from center of crank shaft to center of pedal shaft. If you got enough space in between that and stock you could always go a little longer and try the feel first but if you search for unicycle crank arms you'll find these. I can try to find the info from the place I ordered if you like ? There aluminum.
AKFishOn
  • Date Registered: Dec 2015
Very grateful for the BerleyPro tools I received today. My upper housing caps were seized on, had to place the drive on the floor and put all my weight into the tool to bust them loose. The BerleyPro tool fits perfectly, not sure any other spanner wrench would have held up.
Thanks again AKFISHRIPPER for the prompt to do preventive maintenance. Drive runs smooth as silk now.
AKFISHRIPPER
  • AlaskaKayakAnglers/ A.K.A
  • Date Registered: Sep 2011
No problem, I figured it would be a good heads up. I take really good care of my stuff and it just goes to so regular maintenance is a must.
