November 12, 2026, 10:07:41 PM
[Today at 03:35:50 PM]
Topic: Furling  (Read 19207 times)
Idaho Brit
  • Date Registered: Jun 2016
Well, I guess ill find out. I see no reason why I cant mount the fairlead on the geartrax. Ill make a little spacer to mount it on a 45' angle. That should make it adjustable fore and aft, but the rope coming back may interfere with the fish finder. Ironically someone had just posted about this on the Hobie forum: http://www.hobiecat.com/forums/viewtopic.php?f=32&t=57189
I am considering using Yakataks new anchor trolley system components along the side to improve functionality, aesthetics and keep it all tidy. Surely I'm not the first person to have thought of this.
Hey Browneyes, I don't know about ironic. I'm looking at the coincidence. Red Revo 13 and the same username as yours. MuaHaHa.
Idaho Brit
Rigging a new Hobie Revolution 13 with a rollerized sail and furling kit on Gear Tracks.
Although the factory Hobie sailing and furling setup is simple and works, I felt there is a lot left to be desired. I’m upgrading from the factory Hobie hardware to a rollerized pulley system and mounting on modern Yak-Attack GT90 Gear Tracks. I can’t take credit for many of the ideas contained in this article as much of this has been scavenged from around the internet in different applications.
1)   Tie downs- I have drilled a hole in the center of all 5 of the threaded tankwell bungee cleats and installed ¼-20 stainless eyebolts with a washer and nylon nut.
2)   Furling Kit- The furler is designed to roll up the sail on the mast so you have control of when and how much sail you want to deploy. One association that I made rather quickly was the fact that the furling system shares much of the same concept and needs as an anchor trolley system. So why wouldn’t you want it on rollerized pulleys?
     a)   Fairlead- The factory Hobie fairlead that comes in the furling kit is just a small double cleat that is supposed to be mounted (permanent) at a 45’ on the gunwale near the mast. This is in a very bad place when using gear tracks and is not easily mounted on gear tracks. I have mounted two Harken 29 Carbo Cheek pulleys on a Yak-Attack JK Hatch Accessory Plate to the forward gear tracks. This keeps the ropes outboard of the hull and away from the rod holder or whatever else gets mounted on the gear tracks. The rope stays alongside the hull, tidy and out of the way! All is good here!
     b)   The furling rope- By design, the Hobie factory set-up is supposed to just slide through a ring on a bungee at the rear. Again, why wouldn’t you want this on a pulley? I have simply added a Harken Carbo 29 pulley here. Much smoother operation!
     c)   The furler tension bungee- The hook of the bungee cord is supposed to be attached to a supplied pad eye that is installed at a location somewhere alongside the hull.  In my case, the bungee attaches perfectly to the added forward tank well cleat eyebolt. That’s 2 less holes to drill in my boat!
3)   Sidekick Ama Mounting- The factory Hobie install uses two 3/8” well nuts per side to mount the sidekick AMA cross bar. I'm not fond of well nuts to begin with, and the bar becomes "permanent". Therefore, I’ve chosen to mount the Sidekick Amas on Yak-Attack 8” GT90 Gear tracks with backing plates.
     a)   GT90 Gear Track Mounting- Nothing special about mounting your typical Gear Tracks, but in this case there are a couple things of consideration. The narrower GT90s are necessary because of the available width of the gunwale mounting surface on a Revo. Secondly the mounting location prevents you from being able to reach inside the hull for backing washers and nuts or use of Full-Backs, etc. The GT90 backing plates fit perfectly, but about the only way you can get them there is by “Fishing” them in there- such as done with the use of Yak-Attack (small 8-32) Rigging Bullets. Highly misunderstood, Rigging Bullets, are not mounting hardware at all but rather used as a tool!  And what a handy tool those are!
     b)   Hobie Sideckick Ama Gear Track Adapters- Yak-Attack has the adapters to attach the Sidekick cross bar with a T-bolt and Nut for the Gear Track Mounting. Easy on and off, and no big 3/8” holes to worry about later. Easy peasy.
4)     Main Sail Line- The main sail line is supposed to just go through the rear padeye (same one the carry handle is on) and the main sail line is just to be held in hand by the captain. Not very elegant, and a lot of loose rope!
     a)   I have added Harken 29 Carbo pulley on a  at the rear pad eye. Less friction, and much smoother!
     b)   The main sail line routes back to the pulley, and through the starboard side tank well through the tie downs SS eyebolts that I have added. Nice and tidy!
     c)   Just forward of the starboard Sideckick Ama mount goes a Spinlock PXR Cam Cleat to lock and control the main sail line. This is the item I would prefer to track mount. All I need is track nuts with 8-32 threads. The standard ¼-20 fasteners are too big to fit.  So far, I have been unable to find 8-32 track nuts, so I will make my own in the near future. Ironically the devise bolt pattern fits exactly in line with the GT90 button head fastener spacing! I just used longer 8-32 stainless countersunk head screws, but this makes the mount somewhat “permanent”. This bugger is kind of spendy, but is a SWEET devise for this purpose!
Parts as follows:
Eyebolts- http://www.amazon.com/Hillman-Group-4289-Stainless-5-Pack/dp/B00IAVMG8U?ie=UTF8&psc=1&redirect=true&ref_=od_aui_detailpages00
SS Washers http://www.amazon.com/Hillman-Group-830502-Stainless-100-Pack/dp/B00CAG22C6?ie=UTF8&psc=1&redirect=true&ref_=od_aui_detailpages00
SS Nylon Nut- http://www.amazon.com/Hillman-Group-829720-20-Inch-Stainless/dp/B000B4GU0Y?ie=UTF8&psc=1&redirect=true&ref_=od_aui_detailpages00
Harken Carbo 29 pulley- http://www.westmarine.com/buy/harken--29mm-carbo-air-single-block--2042158
Harken 29 Carbo Cheek pulleys- http://www.westmarine.com/buy/harken--29mm-carbo-air-cheek-block--2042331
Yak-Attack JK Hatch Accessory Plate- http://www.yakattack.us/AAP_1022_p/aap-1022.htm
Yak-Attack 8” GT90 Gear tracks- http://www.yakattack.us/GT90_08_p/gt90-08.htm
GT90 backing plates- http://www.yakattack.us/FB_GT90_08_p/fb-gt90-08.htm
Yak-Attack (small 8-32) Rigging Bullets- http://www.yakattack.us/RB0832_p/rb0832.htm
Hobie Sideckick Ama Gear Track Adapters http://www.yakattack.us/TBK_1001_p/tbk-1001.htm
SS carabineer-SS carabiner http://www.westmarine.com/buy/suncor--stainless-steel-carabiners-without-eye--P002_060_002_500
Spinlock PXR Cam Cleathttp://www.westmarine.com/buy/spinlock--pxr-camcleats--P002_064_002_524
I'm sure there's some Hobie sailors that would like something like this. I would also like to state for the record, I am not “PRO-Staff” or sponsored by anyone, nor have I received any promotional items for this write-up.
Great rig. I've studied your post ad nauseam, ask my wife haha. I used a lot of your ideas, thank you. The pulleys in front really smoothed out the furling process. I made the support for the pulleys out of cutting board and mounted to geartrax like yours. I'm still waiting for a pulley for the rear of the control line which should make it even smoother, silicon spray in the mast tube and on the shaft really helps too. A lot of people commented on the control line running out of travel before the sail was fully furled, I had the same experience. I think the supplied cordage is too short. What I did discover was a work around. If you reach forward and grab the side of the cord which furls your sale and pull on it, if it runs short of travel maitain your grip of it and push it backtowards the mast. Pushing it has the effect of loosening the tension of it sufficiently that the cord will run back over the roller on the mast without unfurling it again. Then you can pull back on it to complete the furling. I dont know if I explained it well but it seems to work for me with speed and effectively.
Thanks again for a great post.
Voyager
  • Date Registered: Nov 2013
I had the Hobie furling system on my Rev11 and found it overly complicated and finicky to use, I did a lot of the upgrades suggested by others but ultimately I found that I could not trust it to furl the sail in a stiff breeze when I needed it, the rope slipped and left me in a dangerous position. I went back to my homemade PVC furler and find it much simpler and trustworthy, I did leave the Hobie furler on the mast and use it as a base for the diy unit but trimmed the bungee cord hook off and use the cord on it to secure mast to kayak
Idaho Brit
Hey Voyager got any photos? It might help some. Have you tried cleaning out the inside of the mast tube. My control line was slipping too, prob was before I got the sail I used the tube for a 1/2 pvc camera mount, the pvc was a loose fit so I had wrapped duct tape around it to improve the fit. That plus water was always in there left a residue that was enough to drag on the mast when furling. I cleaned it out with soap then alcohol and a bottle brush, dried and sprayed silicone and that fixed it, no more binding.
