November 11, 2026, 04:01:29 AM
Topic: Kayak fitted sheets (opinions on heat build up)  (Read 3821 times)
Was wondering what the thoughts are on having TLW custom sew two fitted COTTON sheets together to put over the boats on the trailer for this summer as there going to get a lot of use with any luck. For long term they will be in a storage unit but for multiple day weeks I want them covered as well. Only time cotton and kayak should be used together.  :banjo:
« Last Edit: April 21, 2016, 09:49:18 AM by Mojo Jojo »
DARice
  • Date Registered: Aug 2014
Blue tarp not good 'nuf for you? Probably much better UV protection than cotton sheets...my boat doesn't show any fading after a year in the side yard...but the tarp does.
Trying to keep the heat down and likely no worries about rain on it.
Don't bother with cotton sheets, they will do nothing for you.
Just do a tarp. Get the gray or white ones from Harbor Freight to reflect the UV.
Fine I'll throw out the old sheets
williamesch
  • Date Registered: Feb 2015
What size tarp you want? I work at harbor freight, I'll bring you one on Wednesday.
2016 Angler of the day- 1st place
2019 ORC - 3rd place
2016 hobie outback
2019 old town topwater
2021 Wilderness systems recon
Thank you Williamesch
I'll be using this from now on as my summer boat cover  ;D
They will get a better wrap job in the am I'm tuckered
dandj1958
  • I fish like a girl
Looks good!  Do you have to be concerned about heat build up?
Julie
AKA mrs. dannybay
2015 Hobie Revo 11
2012 Hobie Revo 11
There sitting on the bars upside down or downside up if your bass ackwards like me :banjo:
Not sure if I need to be but I plan on adjusting the tarp so there's air flow under the boats between the trailer and the bars, should I be? I could also make a small light PVC loop like a covers wagon to hold it off the boats. What is the general opinion on heat build up? I am on the bay after all. Input? Anyone??anyone??
This is how they will be covered for summer yard storage. In the storage unit for long periods and over winter.  ;D
Leave your hatches open or at least cracked open.  This gives the hot air inside a way to balance with nature.
That tarp will be just fine as you have it for summer storage.
Dark Tuna
  • "Dark Tuna?"
My experience with boat storage was always with a good quality canvas.  Still seems an optimal balance between cost, durability, breathability, sun and water protection.
With a plastic tarp I think a frame or spacers to allow air to move under the cover would be a good idea.
