November 11, 2026, 07:39:09 PM
Topic: Transporting a yak on a RV  (Read 10028 times)
CS
  • Date Registered: Mar 2015
There are a few companies that make rear mounting vertical kayaks. A bit spendy IMHO. You'll want to keep your overall height below 14'. Mine on the rooftop mount sits just a couple inches higher than the ac unit and I still come in under 12'6" from the road surface. There were a few side roads on my trip that I still brushed overhanging branches and came close to power lines, but didn't hit them.
Yakima makes pretty good rooftop options that may work well on a Class B. Couldn't use one on mine because their longest spreader bars are 88" and my rooftop is 96".
Build a man a fire and he'll stay warm all night. Set a man on fire and he'll stay warm for the rest of his life.
CS
Here's a couple pics of the setup Mojo and I built. He might have some from other angles. Really solid quality and was less than $200 in materials.
Would seem that if standing them vertically was a good idea, someone would have rigged J-cradles on an upright bar mounted in a hitch receiver for a fraction of what that RV Kayak Rack costs.  Even then, you'd be pretty limited to how long the kayak could be and maintain safe clearance.
You have a fiberglass roof and side walls that are nearly impossible to seal, and no real mounting points.  You may not want a trailer - neither did I - but it may be the only solution.
« Last Edit: June 21, 2016, 07:28:31 PM by Tinker »
showa
  • Date Registered: May 2016
I build this for my SUV. Your is much higher, but the idea is still apply.  There is an eye loop close to 1/3 up the post that you need to attach a line, so the arm did not fall to the ground when you release from a close position. You might need a small electrical winch mount in the front to pull the Kayak up on top. Good luck.
IslandHoppa
  • iHoppa
I want to see a Revo 16/Addy mounted on one of those racks. Should be entertaining to see.
Ducka yu head lola bridgeda!
Dang, I want to put my TI on this bad boy!
iHop
