November 22, 2026, 07:06:12 PM
[Today at 05:32:50 PM]
Topic: How to secure items to inside of Hobie hull  (Read 4631 times)
cjweinhe
  • Date Registered: Jul 2016
What is the best way to secure something to the inside of the my Hobie Revo 13 hull?  For example, I have a battery for my  sonar that I don't want sliding around.   Do I just use some velcro tape?
Corey
I use a foam block cut to fit the battery TIGHT and marine hooped it to the hull, no pick right now but I can get you one tomorrow if it's needed.
Pinstriper
  • Date Registered: May 2015
My battery sits in a rack specifically for an 8" hatch. Hangs on the hatch lip. Holds it up out of any incidental water in the hull, too. This is an outback, but do the Revos have an 8"er ?
Sent from my iPad using Tapatalk
Let's eat, Grandma !
Let's eat Grandma !
Punctuation. It saves lives.
Low_Sky
Revos have 8" hatches in front of the seat and aft of the tank well.
2016 Hobie Revolution 16
2014 Perception Triumph 13
My SLA battery is in a watertight box.  I use two 2" x 4" Velcro patches to hold it in place and a couple of small bungees wrapped around scupper tubes (?) as back-ups.
It'll hold the box in place when the kayak is upside down, but it's not strong enough to hold it when the Revo is upside down on the rack while travelling - which is a good thing.
You can cut the inside of the 8 inch tubs that fit the hatches to perfectly fit an 8AH SLA battery. Mount it in the rear hatch and good to go.
hdpwipmonkey
  • Date Registered: Nov 2014
I also use the hobie battery holder in the rear hatch.  I had to make an extension cord for the fish finder though.
Sent from my SHIELD Tablet K1 using Tapatalk
Ray
www.facebook.com/HOWNOC
2016 Junk Jig Challenge
FireFly
Red Hobie Outback
2019 AOTD 5th place
Pinstriper
I use this in my rear hatch....
http://www.kayakshed.com/product/12v-battery-holder/
That's the one I mean. Works great.
Let's eat Grandma !
hdpwipmonkey
Yep, that's the one I use.  Its also made to bolt onto the post inside the front hatch of the Hobie.
Ray
I just put my battery in a dry bag and roll it up then clip it around the sailing mast near the front hatch.
<Proverbs>
I should add that I move the battery between kayaks, so a box held by Velcro works best for me...
Pinstriper
I use that trick for other things, like a pair of screwdrivers and a visegrips and a roll of gorilla tape for emergency repairs. The tools are in a ziplock with a squirt of froglube to fight rust, then it is all in a drybag cliped around the mast.
I just bought a four-piece cheapie paddle for emergencies. Easy to fit through the front hatch, but I still have to figure how to secure the pieces so the one I need hasn't settled to the rear of the hull when I need it.
Let's eat Grandma !
Freeze
  • Date Registered: Jul 2014
I use that battery holder on the post in the front hatch.  A couple weeks ago I purchased a hatch liner which hits the battery holder.  Looks like I'll move the holder to the back.
Some have mentioned the emergency 4 piece paddle.  Is this in addition to the full size one? Or do some only keep emergency paddle for use when not in larger bodies of water?
Pinstriper
In addition to my regular paddle, in case of loss or breakage by me or any others in the party.
Let's eat Grandma !
