November 22, 2026, 06:14:19 PM
[Today at 05:32:50 PM]
Topic: DIY gear track  (Read 4202 times)
danr
  • 2017 hobie outback
  • Date Registered: Nov 2016
I was snooping around on amazon and came across something that i think a lot of you do it yourselfers would like, its called t-track,and a heck of a lot cheaper than gear track, check it out.
https://www.amazon.com/Rockler-17-Piece-Universal-T-Track-Kit/dp/B00EZON1FI/ref=sr_1_4?ie=UTF8&qid=1481776370&sr=8-4&keywords=t+track
Nice... you want to add a few more holes and bolts if your putting any stress on it. Backing plate most likely as well.
Idaho Brit
  • Date Registered: Jun 2016
That is a great option if you only have space for a 3/4 inch wide track. I'm going to bookmark that item. The bolts and nuts are probably zinc plated though but still a cheap option. Maybe just buy the track and add your own SS T bolts etc.
This was discussed a few years back.  One problem is how narrow it is.  With a good sized salmon hitting a rod that is on an extended mount (like a majority use while trolling), you are putting a lot of stress on a narrow track.  Even with a backing plate.  If it is just for mounting a fish finder or other electronics, it should be fine.
danr
you have a good point there craig, and though it migh be a bit bulky, they do have wider versions,( double track) personaly, I can still hear my dad in the back of my head every time i pick up a pole "Boy, if your hooks in the water, the pole is in your hand",  so for me it would be for ff, gopro and whatever other accessories i can think of.
Pinstriper
  • Date Registered: May 2015
Flags, a rocket tube for an inactive rod, bait boards would also be fine. Pretty much the stuff you might mount to the rear.
Let's eat, Grandma !
Let's eat Grandma !
Punctuation. It saves lives.
danr
here is a couple more options. the first link is a double rail 2.5'' wide, and the second is a single rail, heavier gauge
2'' wide, anyway just figured someone might be interested to know there is more options available,
https://www.amazon.com/Bench-Dog-Tools-40-131-DualTrack/dp/B001IKJKD4/ref=sr_1_32?ie=UTF8&qid=1482020201&sr=8-32&keywords=t+track+aluminum
https://www.amazon.com/ALUMINUM-T-TRACK-FREE-Peachtree-Woodworking/dp/B000KUVQY4/ref=sr_1_26?ie=UTF8&qid=1482020201&sr=8-26&keywords=t+track+aluminum
