November 22, 2026, 08:24:41 PM
[Today at 05:32:50 PM]
Topic: Kayak Trailer V3  (Read 5349 times)
smokeyangler
  • Date Registered: Feb 2014
This winter I rebuilt a Harbor Freight trailer that I had.  I made it with a slide out drawer so it'd be easy to get to your gear.  Underneath the drawer I have room to store rods / paddles and other long items.  It is lockable and I can keep my gear in it ready to hitch up and head out to the fishing grounds.
  I welded up the crossbars out of 1 1/2 inch - 3 /16 inch square tubing.  I will be able to haul 4 kayaks on it.  I wanted to extend the tongue, but ran out of time.  I bought a 12 inch receiver hitch extension which seems to work out well so far.
2014 Hobie PA 14
2015 Hobie Outback
Nobaddays
  • Date Registered: Jul 2014
Looks great Mike.  Very functional. I like the ability to lock the box for security while camping.  But what is up with the green kayak?  I have never known you to have anything but yellow.
smokeyangler
Thanks James, I picked up a Jackson Coosa HD for some shallow river fishing, smaller water.  It's for my Top Secret fishing holes.
« Last Edit: March 14, 2017, 07:46:17 PM by smokeyangler »
2014 Hobie PA 14
2015 Hobie Outback
I like it Mike, unfortunately I won't get to see it in June cuz your bringing the rv
Matt M
Nice work Mike!! I really like the slideout drawer. Unfortunately my utility trailer has to be multi use and the big box would make it harder for me to haul other gear. For the purposes of a fishing trailer your setup is perfect!!
-Matt
Old Town Sportsman 120 PDL
Mike looks good. Nice and slick.  The drawer out the back is a great touch.
I would revisit your plan to extend the tongue when you get a chance.
Although you effectively moved the trailer back using a hitch extension basically doing the same thing as a longer tongue would do, you also increased the leverage point seen at the welds of your truck receiver.
Being it's a light trailer you probably won't see any issues with using your Class III receiver on your truck over a long period of time, but if you ever tow with a lighter vehicle with a Class I or II receiver, it will tear those up with any kind of tongue weight or bobbing up and down caused by the trailer movement.
Smitty
  • Date Registered: Dec 2016
What did you use for the slides?
2016 Hobie Outback
smokeyangler
Matt - You could make something like this that you could slide the whole box out when you needed to use the trailer for other things. I.e. Removable box ( container )
Insayn - I will eventually extend the tongue when I get some spare time. I thought about the leverage issue. I'm not worried as I only have about 50-70 pounds of tongue weight.
Smitty - Here's what I used for rollers. I used 3/4 inch plywood for the bottom of the drawer that sets on top of the rollers. I used 2 by 4's on the sides that are installed above the drawer plywood and keep the drawer from tipping when you pull it out. Hopefully that makes sense.
« Last Edit: March 15, 2017, 10:30:53 AM by smokeyangler »
2014 Hobie PA 14
2015 Hobie Outback
jpodyssey
  • Tricity kayak anglers
  • Date Registered: May 2015
Looks good Mike, Im sure you'll put it to good use.
Tricity Kayak Anglers (TCKA) - Director
RAM mounts fishing team
Kayak Shed Fishing Team
1st  Place - 2017 KBF OR-WA Regional May / Bass
2nd Place - 2017 KBF OR-WA Regional April / Ba
SamM
  • McDowellHome
Mike - that looks like a great HF kayak trailer you've built.  I'm sure it will be perfect for you when not hauling the RV !
Also, I agree with Insayn on going with the extended tongue vs the extended receiver.  When I did mine, I flipped the bracket that the coupler mounts to the underside of the A frame, allowing the longer tongue to mount on the same plane as the angled frame pieces.
-Sam
got stop wishing,
     got to go fishing...
          - Jimmy Buffett
Hobie Oasis, Outback, i11s
