November 03, 2026, 07:51:26 AM
Topic: A new addition....  (Read 4734 times)
mtom938
Just picked up this little gem from Wallys for 50 bucks.  Dare I say Okuma has made a "disposable" trolling reel?  I say that because I plan to use this heavily out on the Clay Banks.  Anybody have any experiences with the MA-20DX?   :banjo:
Matt M
The reel works well as a conventional reel, I have caught a few kings on it as well as plenty of ocean fish and a huge mess of sturgeon. The line counter stopped working a while back but the rest of the reel has been solid. It's definitely an inexpensive reel, but as long as your expectations are in line with that then you should be happy.
-Matt
Old Town Sportsman 120 PDL
mtom938
"The reel works well as a conventional reel, I have caught a few kings on it as well as plenty of ocean fish and a huge mess of sturgeon. The line counter stopped working a while back but the rest of the reel has been solid. It's definitely an inexpensive reel, but as long as your expectations are in line with that then you should be happy."
Thanks Matt!  Oh I'm definitely a "you get what you pay for" realist so I think things should work ok with it.  The line counter issue might warrant an autopsy when she gives up the ghost...?
PetitPoisson
  • Date Registered: Aug 2017
Nice find.
I've noticed the line counter reset button tends to stick a little bit.  A little flick and it seems to pop back up.  For WELL UNDER $100, who cares!  The fishfinder tells you exactly how deep you are anyway.
Hobie Oasis (Le Phoque)
I had 4 of those Magda Pro reels which I used for trolling and ice fishing.  I found them to be pretty satisfactory, but after a couple of years of hard use most of them crapped out or had to be repaired. Getting repair parts for a reel is a hassle.  Now I'm mostly using a couple of Okuma Convector CW-203D line counter reels, which is a bigger and nicer-to-use inexpensive reel, and which are holding up better.
« Last Edit: October 03, 2017, 09:20:25 AM by pmmpete »
Trident 13
  • Date Registered: Jul 2016
Pete, is it easier paddling in the snow?  Watching the weather report, lol.
https://www.wholesalemarine.com/okuma-cold-water-line-counter-reel.html?gclid=EAIaIQobChMIwYfuv9XU1gIVRl9-Ch2n2ACqEAQYAyABEgKqsfD_BwE
$95 looks interesting but don't really see if it's a saltwater reel.  This is mentioned, but...
"•Lightweight, corrosion-resistant frame & sideplate"
« Last Edit: October 03, 2017, 07:37:54 AM by Trident 13 »
Matt M
Oh it would definitely be worth looking into fixing, and I probably will next time I take it apart anyways, it's just that at this point I don't care enough to pull it apart to try and fix it. I have a suspicion that some salt water probably got in the line counter area and bugged it up. Probably just needs a cleaning. I will say that I've been using the Okuma "Coldwater" line of reels more and more though. Fisherman's marine here locally runs them on sale for ~$60 once or twice a year and I always pick up a couple. (at least I have been.)
-Matt
A paddle kayak makes a good ice fishing sled with a built-in seat, but a pedal kayak doesn't work well on the ice.
One of my surviving Okuma Magda Pro reels in action on the ice.  I also have an Okuma Coldwater line counter reel, which is the same size as the Magda Pro but with higher quality construction.
« Last Edit: October 03, 2017, 08:32:20 AM by pmmpete »
JasonM
  • Date Registered: Jun 2017
Thanks for bringing this up. I'm looking at picking up one of the left-handed Okuma linecounter reels now for trolling. I've somewhat ruled out the Magda due to it not having instant anti-reverse. I'm OK with spending a bit more since this will be my only linecounter reel and it will have to work reliably. The Cold Water and low profile Cold Water reels are effectively two different price points, so in escalating price they have the Convector ($70+), Cold Water ($95+), and Cold Water Low Profile ($110+). I have never owned a linecounter reel before.If I'm going to use it occasionally for kayak fishing from kokanee/trout up to salmon, what might make it worth moving up to the Cold Water from the Convector, and same for CW to CW low profile?
One of the Convector reels will work fine.  Stick it on an Ugly Stick Medium Heavy trolling rod, and you'll be ready to roll (or troll) with a minimum of financial pain.
