October 17, 2026, 11:06:26 PM
[Today at 09:51:49 AM]
Topic: managing crabpots on a hobie revo?  (Read 10359 times)
Trident 13
  • Date Registered: Jul 2016
Having a milk crate or even custom pipe rectangle with poles sticking up to set the trap on sounds like a pretty good idea.  Line and float under, pot kind of stuck but could come off on a roll-over and still have the buoy attached for retrieval after a righting.  Pretty simple and pretty good idea.  I also like the idea of staying with one trap in many parts of the ocean, but in Puget Sound, weather permitting, I don't have a problem (mostly) with two on the Trident 13.
« Last Edit: December 12, 2017, 07:55:54 PM by Trident 13 »
When I was paddling my Trident, the flatter top of its bow was the perfect place to store and transport the traps (collapsed) going to and from the crabbing grounds.  The side bungies worked perfectly for securing them on each side. That was what I got used to, and could easily straddle the hull and shimmy forward as needed to do what was need to do to get them free
Now with the revo, its not nearly as easy but I do pretty much the same thing. It is quite gymnastics act and a lot less stable. The bow is round, and there are no side bungy cords built in, so the traps can wobble around- especially if its rough. Even then it's a 2-pot limit for me. I probably wouldn't do it the same way if I had to surf launch.  You need to get creative with bungies attached at the very bow that latch on to something at the mast hole, and one to each side gunnel gear trax.
I hand pick each crab out of the pot and put them in a soft sided Costco cooler. When I am done I collapse the trap and wrap up the trap snugly with the rope.
<Proverbs>
Beer_Run
  • Date Registered: Jul 2017
This is my setup on an Outback. It worked great on modestly rough water in Nehalem this summer.  Did the same in Tillamook last Sunday but only put two on but got a limit
Sent from my iPad using Tapatalk
- Bob
2020 Hobie Outback - Seagrass
Beer_Run
BTW.  Cut up Yoga mats are a great addition and prevent any sliding around
- Bob
