November 23, 2026, 11:11:22 AM
Topic: 3D Prints for Kayak Fishing  (Read 8607 times)
no_oil_needed
I've been toying around with lure making with the 3D printer. Here's a picture of the concept model for some jigs.
Relax. You'll live longer.
Wilfite
  • Fish'n's good, Catch'n's better.
  • Date Registered: Oct 2017
I've used Sketchup for a lot of years to design prints.  There is a plugin you can download to convert the sketchup format to a printable format.
-Tony
Wilderness Systems Thresher 15.5 (Yellow)
Old Town Predator MK, (Lime Green Camo)
Cosmo
  • DADventurerNW
Actually what I want to design is the other end of that gear, the female end that bolts onto the piece you have above, so it will fit onto that fitting.
Something like this...
No_Oil_Needed, That's the part I'm looking for.  Your design looks great.  You make it look easy, where I'm sure it's really complicated work.  I found out that Little Cos has access to some pretty awesome CAD software and 3D printers at the Colorado School of Mines.  I dropped him off last week for year 2.  I'm going to put him on this project and see what he comes up with.
Ideally, a mold would be best, as this project will need to have the same strength as the other Scotty components.
Thanks for the help.
Cosmo
2 Hobie Mirage Outbacks 2014
BogFrogDawg
  • Date Registered: Mar 2015
Haven't seen OnShape mentioned here for geometry generation. It's literally professional design software available for free use by amateurs. The learning curve is pretty shallow and well documented by the developers on YouTube. I can't recommend it more, unless you're already proficient on a platform you already own. It's a modern application from the ground up, and they were nice enough to share with us mortals for free. 3d file export once you're done is literally 2 clicks.
www.onshape.com
The years thunder by. The dreams of youth grow dim where they lie on the shelves of patience....which shall it be: bankruptcy of purse or bankruptcy of life?  - Sterling Hayden, Wanderer
craigyb
  • Date Registered: Jul 2014
Not strictly for kayak fishing, but I've published a few bits..
https://www.thingiverse.com/thing:2484091
a 'live fish' salmon dodger
A koke dodger that you print flat, heat up, and bend to shape in a 3d printed mold
https://www.thingiverse.com/thing:2480658
ram and rail mounts for Lowrance depth finders
https://www.thingiverse.com/thing:2480646
And a salmon fender that you print flat, heat up and bend to shape.
When I found out shrimp cocktails had no alcohol, I really lost interest...
