November 22, 2026, 06:13:39 PM
[Today at 05:32:50 PM]
Topic: Revo 13 hull question  (Read 6678 times)
Aquaholic
  • Date Registered: May 2021
Well I was loading the Kayak for the upcoming ORC and found a very unpleasant surprise. The recent heat wave seems to have  warped the bottom rear hull on a my  Revo 13.  Anyone ever have this happen before? And if so how did you fix it?  The warping is slight to moderate. Or would be be best to leave it alone.not sure how much this would hurt the performance or primary/secondary stability.
uplandsandpiper
Flip it over, bottom side up in the sun for a few hours it should pop back out.
dampainter
did it happen when storing it then? how do u store it?? i also would think leaving in the sun may bring it back, maybe persuade it abit?    pics??
« Last Edit: July 05, 2021, 12:21:14 PM by dampainter »
And if this doesn't work on it's own (it often does) search for the Hobie YouTube video of how to use a little hot water and air pressure the hull to remove big (big) dents.
« Last Edit: July 05, 2021, 05:13:37 PM by Tinker »
bogueYaker
  • Date Registered: Aug 2019
Not quite the same, but if I'm hauling my Revo 13 on a hot day, it'll kinda bend around the cart (like, the stern end of the boat will sag a bit). It always pops back as soon as I take it off the cart though. This has been happening a lot more now that I have a sidescan unit which prevents me from placing the cart where I placed it before.
Aquaholic
Thanks Upland I wil give turning it upside down a try. It was stored on a Kayak sling stands supported in very bow and stern points. It seems that the warping is only on the right side from about the rear hatch back. That's the side that got the most sun is my thinking. I was able to get some pool noodles in there and push it out a bit for now. I'm going to give it a test run at Hagg lake tomorrow sometime. See how it handles. The odd thing is the heat didn't bother the PA14 one bit. Its a beige the Revo is Yellow go figure? Then again the PA is also  built like a tank.
