November 11, 2026, 12:22:50 PM
Topic: OR vs WA Regs on the Columbia??  (Read 5749 times)
Beer_Run
  • Date Registered: Jul 2017
OR - Rocky Pt to Bonneville, May 24 - June 15, Open for Hatchery Chinook (adults and jacks) only 1 adult chinook. https://myodfw.com/recreation-report/fishing-report/columbia-zone#Spring-Seasons-(through-June-15)
WA - Rocky Pt to I-5 Bridge, May 23 - Jun 3, Release all salmon other than hatchery jacks. Jun 4 - Jun 15, release all salmon other than hatchery chinook. Also, salmon/steelhead ia closed from I-5 to Beacon Rock. https://fortress.wa.gov/dfw/erules/efishrules/erule.jsp?id=2838
So what is the deal May 24 - Jun 3?? Can we keep adult hatchery chinook or not?
- Bob
2020 Hobie Outback - Seagrass
PLEASE CONFIRM THIS WITH ODFW
I believe the states have a cooperative agreement and it depends on where you land/dock - if in Washington, Washington regulations and if in Oregon, Oregon regulations, and in mid-river, I believe it depends on what state issued your license.
PLEASE CONFIRM THIS WITH YOU RESPECTIVE STATES.
Stinger Hook
  • Date Registered: Sep 2015
Typically regs are the same for the Columbia....
Latest on Washington regs Columbia in season update at: https://fortress.wa.gov/dfw/erules/efishrules/erule.jsp?id=2841
Open for chinook below Bonneville, similar to Oregon
So this overrules the link beer-run had...
Location, dates, and rule:
(1) Columbia River: From a projected line from Rocky Point on the Washington bank through Red Buoy 44 to the red navigation marker 2 at Tongue Point on the Oregon bank to the Interstate 5 Bridge:
Immediately through May 22: Salmon and steelhead: Daily limit 6, up to 2 adults may be retained of which no more than 1 may be an adult Chinook. Release all salmon other than hatchery Chinook. Release wild steelhead. Salmon min. size 12 inches. Shad retention is permitted, no min. size or daily limit.
May 23: Salmon and steelhead: Daily limit 6, up to 2 hatchery steelhead may be retained. Release all salmon other than hatchery jack Chinook. Release wild steelhead. Salmon min. size 12 inches. Shad retention is permitted, no min. size or daily limit.
May 24 through June 15: Salmon and steelhead: Daily limit 6, up to 2 adults may be retained of which no more than 1 may be an adult Chinook. Release all salmon other than hatchery Chinook. Release wild steelhead. Salmon min. size 12 inches. Shad retention is permitted, no min. size or daily limit.
(2) Columbia River: From the Interstate 5 Bridge to a deadline marker on the Washington bank at Beacon Rock:
May 23: Salmon and steelhead: Closed. Shad retention is permitted, no min. size or daily limit.
(3) Columbia River: From a deadline marker on the Washington bank at Beacon Rock to Bonneville Dam:
Immediately through May 22: Salmon and steelhead: Daily limit 6, up to 2 adults may be retained of which no more than 1 may be an adult Chinook. Release all salmon other than hatchery Chinook. Release wild steelhead. Salmon min. size 12 inches. Shad retention is permitted, no min. size or daily limit. Fishing from a vessel is prohibited. Bank angling with hand-cast lines only.
May 24 through June 15: Salmon and steelhead: Daily limit 6, up to 2 adults may be retained of which no more than 1 may be an adult Chinook. Release all salmon other than hatchery Chinook. Release wild steelhead. Salmon min. size 12 inches. Shad retention is permitted, no min. size or daily limit. Fishing from a vessel is prohibited for all species. Bank angling with hand-cast lines only.
Stinger Hook
But Beer-Run, it closed for you! You cought enough chinook already  ;D
Beer_Run
Stinger Hook - Thanks for pointing out my bad URL in my favorites. I have corrected it and you are right, they are exactly the same.
BTW there are never enough chinook  :)
- Bob
My understanding of the WA/OR shared shore cooperative along the Columbia works like this:
Either state license is valid on the Columbia, and can launch from either shore.  Limits are the same.
If you launch from a tributary of either state and travel into the Columbia, all license requirements and limit rules apply for that particular state.
That makes sense.
