June 13, 2024, 11:12:33 AM
[Today at 08:15:37 AM]
by Zach
[Today at 06:12:39 AM]
[June 12, 2024, 01:01:01 PM]
[June 10, 2024, 11:17:34 PM]
[June 10, 2024, 07:16:15 PM]
[June 10, 2024, 12:39:16 PM]
[June 08, 2024, 06:29:12 AM]
by Spot
[June 07, 2024, 11:10:55 AM]
[June 07, 2024, 08:15:15 AM]
[June 07, 2024, 07:28:03 AM]
[June 04, 2024, 12:10:56 PM]
[June 03, 2024, 03:35:37 PM]
[June 03, 2024, 03:08:01 PM]
[June 03, 2024, 01:37:54 PM]
[June 02, 2024, 06:31:12 AM]
Topic: Standard Horizon HX890  (Read 1540 times)
Drifter2007
  • Date Registered: Mar 2017
Does anyone else use the SH HX 890 radio?
I splurged and purchased one. Was very happy with it for the 2 outings it went on. Now it is dead and won't turn on. I am convinced it is the charging cradle.
1991 Desert Storm (USMC)
2004-2005 OIF (US ARMY)
2006-2007 OEF (US ARMY)
2009-2010 OIF II (US Army)
2016 Retired!
Multimeter on the cradle prongs will tell ya if it has juice.
Drifter2007
Yeah, checking with friends to see if someone has a multimeter. I do not.
2016 Retired!
Doesn't it have an adapter to run on a bunch of AA batteries?  That would make it simple to rule out a problem with the radio itself.
Everything will be all right in the end, so if it's not all right, then it's not yet the end.
Drifter2007
I thi k that is an option with this. I don't have the adapter needed......Yet.....
2016 Retired!
Drifter2007
Well.... Looks like I may be incorrect in thinking it is the charger.
Not sure what the voltage is supposed to be, but it is getting 10.2 volts to the charging prongs.
2016 Retired!
bogueYaker
  • Date Registered: Aug 2019
I got an HX890 ~2 years ago, and maybe a half year in it also quit charging. I suspected it was the charger but never confirmed w/ a multimeter.
Now I just load it with AAA batteries.
As far as I can tell the radio is not good for my needs. It burns through juice -- just this weekend it died after 6 hours on the water, starting from a fresh set of batteries.
I wish I'd returned it when it was under warranty. I won't be getting another.
kemfish
  • Date Registered: Apr 2021
I have one, I need to "rock" it in the cradle until I see the charging sign come on.  Just a poor connection I guess.
Decided it was too much radio for my needs so got one of the lower models which better suits what I need a radio for, talking to you guys and the coast guard.
Keith
Old Town Sportsman 106 PDL
jp52
  • Date Registered: Jan 2018
When you put it in the charger does the charging symbol come on? I have a HX870 and I have to clean the contacts on mine when they get dirty or it won't charge. I put a coat of dielectric grease on them to keep them clean longer.
Drifter2007
No, mine gives no indiction that it is connecting to the charger.
2016 Retired!
Try cleaning the contacts on the radio maybe.
I have an HX-870 that does the same thing when on the charger - no lights, no beeps, no nothing.
BigFishy
  • Date Registered: Nov 2020
Mine is working flawlessly for three seasons now. I really like this radio. I believe when you use AA batteries the run time may be decreased as opposed to the stock lithium battery.
2021 Hobie Outback
Larry_MayII_HR
  • Date Registered: Jun 2017
I also have the HX890 radio - it has been working very well for me for 3 years and I have had great battery life from the stock lithium battery. I am sure AA lead acid batteries would have lower life than a rechargeable lithium.
The troubleshooting suggestions offered by others seem like great places to start. You can get a cheap multimeter at HF....just don't use it for utility work and you should be fine. Don't let the magic smoke escape!
I hope you are able to revive your radio. Good luck.
