November 06, 2026, 03:04:37 AM
Topic: Lo-budget Vanity Camera Mount  (Read 11232 times)
Wicked Dan (msgdan) made this nifty self-portrait camera mount
http://www.kayakfishingstuff.com/community/showthread.php?t=61508&highlight=mount&page=4
and I said I was going to cobb together one of these in PVC. Well, I finally found one of those round tuits. Mine is made to fit in the Hobie mast hole, but it could easily be adapted to any rod mount.
 The first one I made out of short lengths of 1" pvc, two couplers, an elbow and a tee. The idea was to make it stowable.
I added a 1/4" bolt to one of the end caps to mount the camera, then decided to screw the camera mount from a cheap mini tripod to the cap (made it waay more adjustable) It worked ok, but it had too many parts.
Then, in a momentary lapse into brilliance, it occurred to me to string them together with a bungee. That keeps all the parts together and makes it practically self assembling. So I did, it worked.
The bungee is loose for the picture. For the final assembly, I took up all the slack plus a bit and tied it off to a hole drilled in the pipe where the loose end is.
http://www.youtube.com/v/TOUKMUEn1ow&hl=en&fs=1"
 I built another one in 1.25" pvc to make it a bit stiffer and I used the thinner pvc (sch 30?) to minimize weight. I found a small spider tripod and decided to leave it intact. Instead of screwing it to the cap I just shoved into the end of the pipe . Simpler and I can use it elsewhere.  $8 PVC and fittings+$8 mini tripod Total <$20   Add a wire and an SMA connector and you'd  have a cheap dipole to extend your handheld vhf's range too! ;D ok, maybe not.
Here's a link to an earlier discussion with some picks of Dan using his mount. I'll post some better pics as soon as I get out and catch some more fish.  ;D
http://www.northwestkayakanglers.com/index.php/topic,1677.0.html
« Last Edit: May 03, 2009, 05:18:59 AM by Fishesfromtupperware »
andyjade
  • Photo Dump
Beats the heck outta paying for Go Pro mounts.  Well done, man!  Good thinking!
Blog/Photo Dump
Brilliant and cheap! Just what I'd expect from FFTW!! :D I love the bungee idea and the video is especially CUTE!! One question I do have. Is there a reason to have the pvc extending down into the water?
It floats a bit to better support the camera and puts less of a load on the pivot. I forgot to mention to stuff it with pool noodles or spray foam.
Gotcha! I'm going to get to making one of those ASAP!
Nice Wali, You got a new Hobie?
Yep. The orange channel marker caught the drivewell leak. But you gotta love that Hobie customer service!
« Last Edit: April 23, 2009, 07:15:02 PM by Fishesfromtupperware »
Love, love, love Hobie costumer service.  ;D
So, stupid question, i take it you use the timer to take the pics? and it takes a little  practice to get the aim right i suppose.
HBH
  • Date Registered: Dec 2007
guess i am stupid too...i was going to ask the same questions...maybe a long stick to push the button? ;D
Timer
Roy, I'm still working on some registration marks to line up the camera for one shot. But for now it still takes a bit of fiddling and a shot or two to get it lined up right.
« Last Edit: April 23, 2009, 10:20:58 PM by Fishesfromtupperware »
Nicely done Wali!!
Does the camera float create much drag?
It really does not drag that much in the water as I'm usually stopped when I doing the vanity shots. :D Then it breaks down as quickly as it goes together and gets stowed in the tankwell.
squidgirl
FFTW
how long do you set the timer for?
Learning a lot of very cool stuff here
FFTW   8)
FTTW, I would like to award you the coverted MacGyver Award, however it would need to be awarded to nearly every member of the NWKA and I don't have that many mullet wigs.
Very cool design.
