November 18, 2026, 07:59:41 AM
Topic: Rod tube launchers  (Read 6553 times)
Many of y'all have rod holders, the launch tube types on your milk crates and live wells.  Where did you get them?
Yeah, I agree with steelheadr.
When I used a milk crate, I just zip tied some pvc tubes on the back of it. It's a bit ghetto, but it works great and really cheap!
I have no problem with "ghetto", but I like the slot for my spinning reels.  Cutting a slot seems difficult.
yeah, it can be a pain.
I just used a high speed drill with a grinding wheel. That can get messy though, nice to have some goggles.
Another vote for PVC/ABS
I did mine with a manual jig saw.
squidgirl
PVC.... like pool noodles the universal tool.
 It makes good holders for anything. and i used a small key hole saw with a pvc blade on it.. hell if your really inventful you can actually cut PVC with fishing line. takes a while but the heat melts the pvc.
yessnoo
  • Date Registered: Apr 2008
berkley also makes a set of 3 that a few guys have around here...there like 12 bucks...so its not like its alot of money
but i don't know how well they would work on a crate...they work well on plano boxes though
I cut slots for the spinning reels with a Dremel tool sanding attachment. It took about 90 seconds for each pipe.
Thats what I use on my plano, can't see why they wouldn't work on a crate, perhaps with a backing plate.   They work great and have held up so far.
« Last Edit: May 11, 2009, 08:32:06 PM by pelagic paddler »
yessnoo
Quote from: yessnoo on Today at 01:12:37 PM
ya i just don't have one so i couldn't remember how the mounts were oriented
 Seems like a grinding wheel would get too hot and melt it doesn't it?  I like a jig saw and a hole saw for slots in PVC (or anything else on poly boats come to think of it).
  The other really trick tool for yak pimpin is a deburring tool. Home Despot usually has a cheap version of one that will do the job in the plumbing department for about $10 bucks. It is worth its weight in gold! Its great for carving off a bit of PVC or plastic at a time.
 You drill or cut the hole slightly undersized, then open it up with a few turns of the deburrer.  It works especially well for cutting holes in the boat. You'll end up with a dang near water-tight seal with no goop! Its also great for sharpening that tubing that you used to cut grommets. No kayak pimping kit should be without it.
http://www.deburringtools.com/a_rdt.html
I suddenly realized, "Doh!  I have a radial arm saw."  In quick order I had 4, 17" long, 1-1/2" diamter, PVC tubes with slots.  A dremel cleaned up the bottom of the slot where the radial arm left it chisel-like.
Life is good.  Thanks, all.
Why not drill a hole in the PVC where the slot will end, and then cut your slot from there out with a jigsaw?
Even faster would be to pinch your PVC between two boards of equal height. Set up a guide fence, and hit the PVC with a router.   May also want to clamp the opposite end of the PVC down to the table.
don't forget to try this idea from jim sammons.
http://www.kayakfishingtales.com/
look at the menu on the right side, under rocket launcher.
if you have trouble getting the video portion of the page to load, and are using a version of internet exploder, look up at the right side of the url bar where your stop and refresh buttons are. you should see a page icon. click that. it's something M$ calls a windows compatibility viewer feature. the page should refresh, then you should be able to see all the video stuff and get it to function.
'don't ask me how i know"
