November 12, 2026, 07:02:46 PM
[Today at 03:35:50 PM]
Topic: Modifying my penn 320gt2  (Read 4013 times)
yessnoo
  • Date Registered: Apr 2008
Well I ordered all the stuff to put new drag washers and run greased drag fittings in my penn 320gt2 in accordance with Alan Tani's rebuild...its a three year old real that has never been taken apart until today but it looks in pretty good shape...virtually no corrosion...I guess washing it down after using it really does help lol...Either way I got some cals drag grease...and corrosion x on the way so I can get it all ready to go...
Anybody used the extreme reel + that alan tani uses?
I've been looking for a local retailer to carry it but I've only found online sources. Maybe you'll have better luck in the Seattle area.
Jay
Not sure you're going to need that kind of protection over Corrosion X.  I believe the Extreme Reel is formulated for higher drag temps than Corrosion X.   Keep in mind that Corrosion X will protect your drag up to something like 500ºF.  You'll have a hard time holding onto the reel by then.  ;D
When I ordered the C-X, in the larger hand pump bottle, I found that it is tough to get "just a drop" on the bearing as suggested.  I ended up rinsing out one my old eye drop containers (post Lasik care), and filled that with the C-X.  Works a lot better for drop control, and mess.
yessnoo
well i wasn't going to use either for drag...i'm using cal's drag grease for that...i'm assuming you mean bearings...but according to alan tani the extreme reel + has superior lubrication which leads to much better freespool...granite i don't really cast my 320 very often so i probably wouldn't notice much difference accept free spooling to the bottom lol but its just because i like tinkering with stuff lol
just like theres nothing wrong with my drag...i haven't lost any fish due to my drag that i know of...but here i am still doing the upgrade lol
good idea on the eye drop thing...now if i just had an eye drop bottle...maybe ill just go buy a dropper at target
« Last Edit: June 13, 2009, 06:05:46 PM by yessnoo »
Duh!  My bad, I was thinking Cals on the drag when I was talking temps, and got the two mixed up.  Anywho, I don't cast very far with my gear either, so searching for the "better" lube just didn't need to happen.  I wanted salt worthiness and bearing life, and that's about it.   But tweaking with the tools is fun for sure.
When ya go shopping for eye drops, go for the cheapest brand that you can see yourself pouring in your bosses coffee cup.   >:D
That way your not pissing away $5-$10 for the use of the silly little bottle.    I'd suggest you swing by an eye clinic, or place of that nature and see if they have any product samplers they will give you.  Don't tell 'em its for a fishing reel.   ;D
