October 27, 2026, 05:45:18 AM
Topic: The self rescue!  (Read 90513 times)
You are right. Judging by what I have seen on here, most people's caskets would be made of PVC from Home Depot, lined with pool noodle foam from the dollar store.   ;D
Hey!!!! That was going to be my new business idea!  But my policy would be I wouldn't sell that kinda coffin for accidents. Only if you died of old age and as an avid kayak fisherman.  The idea is cool enuf i dont want to encourage risky behavior!
So hush!
But seriously, the other poster saying wear chains if that's how you fish holds true. I would have taken my jacket and sweater off at the end of the day if I wanted to practice. But THATS exactly what would have weighed me down
Glad to hear hear Allen say stirrups because I have two of them. I also have a buoy set up for harpooning big halibut that allows for attaching to the end of the paddle.  My downfall is I haven't tried any. But I have multiple options to try: normal self entry, two stirrups wrapped around both handles, and a paddle float set up.  But I agree, no substitute for practice. How hard could it be with practice?  Divers use sot kayaks. Would REALLY suck for them if they couldn't get back on!
 I need to practice but DAMN it's COLD even in the summer here.  Next spring I PLEDGE to practice more.  Besides I want to try some surfing AFTER a successful day of fishing.
Ya know if someone wanted to put on a cold salt water self rescue clinic, practice day with no boat traffic or much of an audience around I'd suggest Whalen Island just past Sand Lake on your way south to Cape Kiwanda.  The water is ocean cold salt, and there is a nice 28 foot deep hole to play in. More than enough for many kayaks to play at the same time. It gets ankle shallow on 3 of the 4 sides pretty quick so if a person is having issues, they can float to any side and try again.  The launch is merely feet from the deep hole, so it's really easy to get on the water.
Alkasazi
  • Alkasazi
yep, a paddle float can be used to help re-enter a sit-on-top. combining it with a stirrup can make it really easy. the paddle float can also come in handy for a variety of other things, so I tend to always carry one.
crawling on from bow or stern also works well for some. keep your belly in contact with the boat, that helps keep your center of gravity low.
and to echo several others, practice, practice, practice.
Any one try the paddle float technique the SINK guys use?  Seems like it'd work even better on an SOT.
Dan_E
  • Formerly known as Indyflyer
  • Date Registered: Dec 2010
I appreciate the timeliness of the thread, as I learn to paddle a SOT and how best to get it set up.  I have a stirrup on my Pungo SINK, but can't see how to attach one to a SOT.  Anyone have pics or description of deploying a stirrup on their SOT?  Are you using it looped around your paddle as I've seen some others use?
Alkasazi
  • Alkasazi
Yes, I would loop around the paddle. here's a video of it being done with a sit-inside. would work the same for sit-on-top, minus the wriggling into cockpit:
ps - I'd recommend forwarding through blowing up of the paddle float.
Dan_E
Thanks for the video link, I remember seeing a demo several years ago and will revisit the idea now that I am using a SOT.  Using the legs to hoist oneself back in the kayak is much easier than hoping your upper arm strength is enough.
You been in my garage again? ???
Most folks did not consider self rescue reentry when setting up accessories
(rod holders etc) on their yaks. Many of the yaks had gear mounted all over the deck and a person would have to drag over the top of it making the likely hood of snagging your PFD a problem and reentry more difficult.
I'd agree that you need to practice re-boarding fully loaded. But for the first foray you might want to try it naked.
Well, maybe with the a pfd and drysuit, but with the boat un-rigged and certainly no rods.
I have to be honest, I was thinking of you when I posted, but didn't want to name names. ;)
« Last Edit: December 14, 2011, 07:47:02 PM by craig »
Zee's demo is good, and the simplest form of self-rescue.  Most folks who choose to do what we do should be fit enough to perform it.  However, in rough water or if highly fatigued or if weighed down it could be a challenge.
The other video shows the use of a paddle float and stirrup.  It seemed like a long, involved procedure.  Fine for flat water as in the vid, but probably a bit more difficult in wind and swells and chop.  I'm thinking something similar but simpler.  A simple stirrup to help with Zee's "good kick".  Just a short strap or line with a snap on one end and a loop on the other.  It should be small enough to carry in your PFD.  Snap it to the carry handle on your side (I'm thinking selfishly of my Revo), put foot in loop, then proceed with Zee's procedure.
I've never tried a stirrup, but I suppose a potential issue is flipping the yak over you.  Real world experimentation is in order.  Sounds like fun!
Had a little reentry practice last weekend with Josh. The Self Rescue Ladder seems the most simple- Especially for flipping wide boats back over. I wouldn't want to try flipping a PA back over without one of these for sure! As stated earlier, physical fitness and fatique play a large factor.
<Proverbs>
That's a pretty elegant solution.  I'll have to give it a try sometime.  I'm not sure if would help in the surfzone though.
Romanian Redneck
  • snoodleboob smoochy bear
You made that look easy. Great video!
Sent from my iPhone using Tapatalk 2
RR's Channel
- Jeff Foxworthy
In the surf zone you just get your a$$ handed to you!
<Proverbs>
TVET
Very informational, thanks Zee!  Now all I need is a kayak to practice with, can't wait.
threecreeks
  • Date Registered: Aug 2007
I'm down here sitting in Cape Lookout State Park enjoying the read. Lots of great info to be gathered. Completely agree with Pelagic's commentary regarding deck set-up. Seems like a clean deck is a safe deck. When the inevitable huli occurs, the less in the way for quick re-entry the better. The less flotsam to collect the better, too.
When I was setting up the Fish-N-Dive I found some picks of other set ups from the more experienced and well traveled folk in here's Fish-N-Dive pics (Spot and Pelagic). It wasn't just about the where something was put but the how's and why's. It also seemed like the ocean pics of their craft were streamlined vs. the river pics.
Zee's tutorial was great. The one thing I'd add fwiw is just simply this....don't panic! Taking lessons learned from years of whitewater and swift water rescue experience, panic makes simple tasks into rocket science. Taking a few seconds to take a mental inventory of your situation and maybe even laugh a little will allow you the time to collect your thoughts and then concentrate on the task at hand. Getting back into your boat. If you're dressed for immersion you're not going to freeze. If you have a clean deck, you'll have little if any flotsam. If you don't pre-think your re-entry, you'll miss. Misses equal fatigue. Better to take a minute or 30 seconds or whatever time you need to think and make a good solid re-entry then tire yourself out with many attempts. Seems like every time I've dumped in the surf, if I'm able to forget about the sharks that I'm sure are gonna eat me, I just relax, inventory, pre-think the re-entry and flop on up.
Thanks for a great topic!
