October 29, 2026, 06:07:39 AM
Topic: Need to cover some distance.  (Read 7012 times)
Oooooh, man , you're giving me ideas!!  Would you go the "ama" route, or just the sail and use the Mirage fins as daggerboard??
My loose plan was to try it sans the ama and just use the sail, fins, and rudder.  Depending on how that worked out, I might progress to outrigger(s).
I mounted an aluminum bar just aft of the Revo's mast hole and I could mount a similar bar behind the seat and use it for an ama on a telescoping mount.  Seen something similar on Aquahunters.
I've never been interested in sailing as the few times I did I was bored out of my mind, so I would need to flounder about and read up on general sailing principles before I felt comfortable sailing with my fishing gear.
