November 05, 2026, 10:53:43 PM
Topic: Other Halibut landing tools  (Read 4296 times)
Here is my go at making a flying gaff of sorts for dealing with halibut.
The hook is a 14/0 Mustad shark hook 20' of 1/4 twisted nylon rope so I could splice both ends a cheap crab pot buoy and a smaller float to keep the buoy from sliding off the end.
I think for most medium sized fish I should be able to use it like a gaff hook but with some line to play with and if it really is a big fish I will just dump the buoy.
There isn't a ton of floatation to the small buoy but I didn't like the idea of lugging around a big ball.
Hopefully I have to test it out soon!
That looks pretty sweet! Where do you fish for them up there?
BTDT.  The very first halibut hookup I did with Fishin-T years ago, Tom brought some of these large shark hooks.  They work well.
I've been known to use a large dry bag for a float when on remote trips.  Use the dry bag to pack your clothese then pull double duty as a gaff float.
Halibut is open from the CR all the way through the straights. Our season is very short up here. Some areas only have 4 days for the entire season!
The most kayak-friendly areas to fish are along the Strait of Juan de Fuca. The outer coast can be brutal for launches.
That said, there is a little known opportunity in area MA2 for halibut, 7 days a week, inshore. It's meant to allow incidental catches during bottomfish trips from Westport. The sub-quota is usually pretty small, but since most people are using rockfish gear and fishing reefs, the catches are small in number. There is usually a similar opportunity in OR, north of Cape Falcon (though I haven't checked this year's regs). I've used it on a charter trip out of Garibaldi that fished the boilers off of Cannon Beach. I was using a big white curly tail jig with a teaser above. When we drifted away from the rocks, I would let the jig drag the sandy bottom. Had two hookups one day, landing one 40# "but.
Here's the language from the WA MA2 regs-
Northern Nearshore HALIBUT Fishery: Open to HALIBUT
fishing beginning May 1, seven days per week until the
sub-quota is reached or Sept. 30 for those waters from
47°31.70' N. latitude south to 46°58.00'N. latitude and
east of a line approximating 30 fathoms as defined by the
following coordinates: 47°31.70'N, 124°37.03'W,
47°25.67'N, 124°34.79'W,
47°12.82'N, 124°29.12'W,
46°58.00'N, 124°24.24'W
