November 06, 2026, 11:21:18 AM
Topic: How do I care for the Mirage drive????  (Read 5840 times)
Yokut
  • Date Registered: Mar 2010
I am curious to what everyone is using as lubricant on their Mirage drive systems? And what is the best way to take care of them? Appreciate all your imput. - Yokut
The best thing to use is dry silicone spray for the chain and cable system. It's spendy. WD40 works to  but i like to make sure and wipe it off the rubber flippers.
I also dab a little marine grease on the crimped parts of the cable/chain and the main shaft. doesn't hurt to dab a little grease on the clips that hold the drive in too.
Rinse it every time you use it especially in saltwater and give it a light spray with the lube for the longest life.
Thay are pretty durable...
Pixster
  • Date Registered: Apr 2010
I always carry a container of water with me and give the MD a rinse (assuming salt trip) before going home. At home I follow-up with a good spray from the garden hose. Every 2nd-or-so trip from the salt, I lube it with Break Free.
Good read if you haven't: http://www.hobiecat.com/forums/viewtopic.php?f=60&t=12577
Pretty much the same here.  Spray it off vigorously with fresh water when I get home.  Lube every couple trips with WD-40 at every place parts move against each other.  I also put together a spare parts kit I carry in the truck.
(1)   V2 Chain assembly
(1)   Turbo fin replacement
(1)   V2 replacement injection molded sprocket
(1)   Pedal strap replacement (right)
(1) Pedal strap replacement (left)
(2)   Turbo fin replacement mast (Threaded V2)
TOTAL   125.70
Great tips guys. Cool thing about the MD is that it's not a fragile piece of hardware. If you're rinsing it w/ freshwater and check up on it every now an then it'll keep on trucking.
I thought you stored it at the bottom of a river for a few days at a time ...   >:D
That's just to soak off the real built up grime...
The way Hobie owners talk about them, I'm pretty sure they keep their mirage drives in their bed and cuddle up next to them at night.  :)
Just like your canoe, costume, and soundtrack..  :laugh:
Stumblefish
Bsteves gonna do a mirage drive freestyle act?  Phantom of the outback?
rrdstarr
  • Date Registered: May 2010
The way my right shoulder keeps acting up I think I might by a mirage drive next season!  Frees up the hands for fishing! and drinking!
-Rick
Pygmy Boats - Borealis XL
That is one reason I bought one.  My elbow is messed up.  Also, It does make beer drinking easier.
Ditto.  Bad elbow here.  Frees up the cigar hand.
Is that what they are calling it now?? :toothy10: Just kidding.
-Craig
