October 27, 2026, 04:09:48 PM
Topic: Transducer mounting  (Read 13999 times)
ronbo613
Do you fill that tube with water?  Or is there goop on the bottom inside of the tube?
There's Lexel inside the tube. It takes a couple days to cure, but when it does, it's in there for good. It gives a very accurate sonar reading and temp as well.
  • I fish out of a SIK
  • blah...
Just an update in case anyone was curious....
As Z suggested, the hull was fine and air was the problem...
I showed my setup to Bsteve's last week when we were bass fishing on the Willy, he pointed out the fact the closed cell foam I was using had air in it.  I had missed the part about making sure there was no bottom to the "tray/puck".  I cut out the bottom of the foam, then gooped it down, took it out last night to try it out...
 Awww ya...  ;D
