November 22, 2026, 07:03:51 PM
[Today at 05:32:50 PM]
Topic: leaky deck plate  (Read 3601 times)
boxofrain
  • Date Registered: May 2006
Hey All!,
 I have a deck plate that leaks a bit. Does any one have a suggestion as to how I may stop this?  :dontknow:
 I can't light a phattie when it's all wet!  :help: :laughing6:
 Thanks
Ummm ... put your phattie in a ziplock?   :tongue3:
OK.  I guess I didn't answer you real questions.   ::)
Check the o-ring in the deckplate.  If it's cracking replace it.  If it looks good, give it a coat of, oh shoot I forget, some material that is meant for o-rings to keep it pliable and supple.  Clean out the o-ring channel and replace o-ring.  Check the plate ridge that mates with the o-ring.  Know down any sharps burrs, grooves, etc, that may have accidentally formed.
Another thing you may want to check.  Remove the deck plate completely and replace, but first put down a bead of goop.
boxofrain
Thanks Allen!,
 I have cleaned it up well with a toothbrush,examined the o-ring. Found a few small dents in the surface of the o-ring, before ordering a new one, I took Boulster's advice and put a large rubber band I got off of some broccoli or something around the plate cover.
I need to put the garden hose to it for a test
either way I will order a replacement or two, I need to order a deck plate for the back of my P-13 any how.
On the subject of deck plates, can I remove the center plate I have and cut out the plastic "bowl" and put the plate back with a cat bag? Seems doable to me, no prob.
 Any one do this all ready?
Thanks for ALL THE HELP
NWKA ROCKS!
NWKA ROCKS!
Yes it does BOR... yes it does! :headbang:
BTW get the current issue of F&H news. Has the article about yak fishing and tons of quotes from us. Pole2 even got a quote up front about the salmon shark fishing.
