October 04, 2026, 08:41:12 PM
Topic: Kayak Cart  (Read 7254 times)
Ranger Dave
It is a little loose, but it should work fine.
That's what she said.    ;D
You beat me to it insayn...I was going to say, "Yeah, that's what my ex said"  >:D
Wouldn't it be great if you could have those things re-sleeved like a Chevy Vega  ;D
jstonick
Following all of the advice here I made my hard wheel setup for my Hobie cart today. Instead of PVC I ended up using the hard plastic pipe that is used as part of a lawn irrigation system. The nice thing is that I could buy one 8" piece for less than a buck and use it for the set offs for both sides.
Also I am not sure of the others' wheels but mine have no bushing just a hole through the plastic. When I looked at the Harbor Freight Tools in Cedar Hills these looked like the best choice ($6.99 a piece). The entire addition ended costing about $19. I may need to thin the clips a bit as the wire is a bit thicker than the width of the groove.
That turned out looking good.  It should be much easier getting up that launch at George Rogers. :)
firebunkers23
