November 07, 2026, 11:12:16 PM
Topic: Crazy or should I try???  (Read 5893 times)
Kenai_guy
Hopefully I'll be able to strt catching halibut out at deep creek by then.  Only time will tell
9th place 2014 ORC
That was on the lower Kenai.  Slow fishing but fun.  The cart works great as long as your tires are aired up
+1 on the needing air in them tires.  The last time I tried to pull my revo behind me with one low tire I got a serious work out!
Kenai_guy  I love your setup!   8)
DON'T AIR YOUR TIRES!
Those wheelez tires are ment to run on low pressure ~3#. They work amazing over rocks and soft sand. If you want hard tires get another set and swap them out.
Kenai_guy
Maybe I should have phrased that differently.  They work great as long as you have the right amount of air in them.  I had some issues a few weeks ago, but it was 10'F outside.  Not enough pressure for the temp
9th place 2014 ORC
DTS
Quote from: Fungunnin on March 20, 2012, 10:35:14 am
Yep!  My tires really had no air in them when I got my workout.  2-3# works great,  but yes I agree if you are going to avoid the sand/rocks then hard tires is the key.  :)
PROGRESS IS JUST BEING THERE!
