October 27, 2026, 02:44:03 PM
Topic: Hobie mobile repair kit  (Read 5856 times)
I recently moved my bottom fishing tackle from the large plano watertight box to two smaller ones (so they fit inside the 8" hatch).  The large plano box is now serving as a Hobie repair kit.
Contents are:
Pliers
Wrench
Screwdriver
2 standard sized rudders
4 standard sized mirage drive fins with posts
Loc-tite glue
Zip ties
We both have spare rudder pins in our rear hatches.
What other REPAIR specific equipment would you recommend?  I'm NOT asking about flags, bilge pumps, first aid kits, etc.
This box isn't designed to be on the yak all the time, just on long range and camping trips.
An extra threaded sprocket and chain assembly.
You have a pretty good repair kit as is.
I would throw in a few extra nylox nuts for the drive cables,  a spare rudder pin and either replacement rudder cables or heavy braid.
micahgee
Looks good.
I add spare drain plugs and a couple of pad-eye screw-in attachments for the seat and bungees. Last summer busted my seat pad-eye on the water which was a pain.
www.heroesonthewater.org
Maybe a small tube of goop.
Some silicone grease and dry silicone spray.
Good ideas all.   Where is the best place to get those two items Roy?
Pixster
  • Date Registered: Apr 2010
Duct tape and 550 paracord.
lots of places:
home depot
lowes
radio shack maybe
photo&video stores
walmart
sears
Online too
http://www.amazon.com/3-IN-ONE-10041-Professional-Silicone-Lubricant/dp/B000BBYCUC
http://www.amazon.com/Synthetic-Grease-Syncolon-Purpose-Lubricant/dp/B000XBH9HI/ref=pd_cp_hi_3
islandson671
  • Heroes On The Water NWest
  • Date Registered: Jun 2010
WD40 and a Craftsman wrench....sorry been listening to country music
Sent from my DROID BIONIC using Tapatalk
willbd
This is what I have, but other than the spare rudder pins and pedal straps, the kit has been staying in the truck.  I figure I can always paddle back to the launch and accomplish repairs onshore.  I may rethink this strategy and secure the repair kit in the front hatch in a waterproof box.  Other good ideas from this thread may make it into the kit, like rudder cable, screw-in pad-eyes, and goop.
Hobie Mirage Drive Repair/Spare parts kit:
(1)   V2 Chain assembly
(1)   Turbo fin replacement
(1)   V2 replacement injection molded sprocket
(1)   Pedal strap replacement (right)
(1)   Pedal strap replacement (left)
(2)   Turbo fin replacement mast (Threaded V2)
(4)   Stainless Nylock nuts for cable ends
(2)   Rudder pins
I feel the same way.
yaksurf
My mirage requires an Allan wrench to tighten the mast down.  Also for a long range or car kit I keep some wire nuts and wire connectors it saved me one day I was able to repair the wire and use my FF.
