November 06, 2026, 09:33:43 AM
Topic: Hobie Turbo Fin type  (Read 3380 times)
Nick
Ok, before I order the turbo fins, repair kit for my rudder, etc etc... for the used outback I purchased, I want to make sure I am ordering the right set of fins. I'm fairly sure I've got the threaded version, as the rods have a small hole in the end probably used to tighten them into the drive, and I don't see a visible setscrew. It could be possible one is hidden in the plastic piece, but I doubt it. Can you guys tell visually by my pic and verify I have the version two threaded masts? Thank you for your wisdom ahead of time! :)
That looks like a V2 drive with the threaded masts.  The V1 has obvious set screws.
Nick
Thanks man, appreciate it  :)
Nick
Nick
Welp.. the setscrews... I found them as I went to put the new fins on ... so i ordered the wrong ones. maybe someone in the future can read this thread and not make the same mistake  :'(
Nick
So, this was my fault for looking for setscrews at midnight or so in the dark with a flashlight in the back of my truck, not exactly optimal conditions. but just so noone makes the same mistake, here is a pic of where the screw is. at first glance ya might not catch it as it sits behind the fins, and is mostly hidden when the fins are installed.
micahgee
Bummer,
I'd see if you can return the fins.
Heres a picture I found comparing V1 and V2 fin attachments, called sprockets IIRC:
www.heroesonthewater.org
Nick
man, i sure wish i saw that pic a month ago! Yeah I will prob have to pay shipping but get it swapped.
If you can hang on to them and still afford the olde set, I'm sure someone from this forum will come along soon with a new Hobie wanting to upgrade fins.  Probably even in your neck of the woods.   8)
Nick
Thanks Insayn, money isnt that tight, but it enough I don't want to wait on! I called seller today and they are gonna swap it for me :)
