November 12, 2026, 12:19:55 PM
Topic: What paddle do you use?  (Read 11091 times)
Ed Call
  • Date Registered: May 2012
Aquabound fin stalker.
Kayak fishing?  I have no clue, but I'm doing it.
WayneWhit
  • OK Trident 13, OK Prowler 11
  • Date Registered: Oct 2009
Carlisle Magic Plus
Werner Shuna carbon...as a Hobie guy using this paddle is like putting hubcaps on a tractor ;D
You earned your stripes man, you can use any paddle you want.
yaksurf
I keep a hobie paddle strapped to the side of my outback I didn't know I was supposed to use it.
Sure you can use it for stuff. I use my Hobie paddle to pick trash out of the water and adjust my GoPro if the fishing rod doesn't work.  It can be used as a shovel, too.
Quillback
Werner  Cascadia - use it for both Hobie and Kaskazi
hydrospider
Its tough to call one a primary.
But, Id still like to help and I do have a current favorite.
Its the Saltwood "double happiness" 220 bent shaft twisted to 20.
A close second is the Werner Corryvreckon 240 bent shaft also twisted to 20.
The other paddles are for the non fishing paddle trips.
The SLF uses the Camano.
Until Saltwood caught my attention I was all about Werner.
The Nothing
  • De nihilo nihil
  • De nihilo nihil
  • YakFish@IOL
I just did a motor swap last week
~Isaac
Blog 'YakFish
Adventure Technology Ergo Tour T4 Carbon
koboabe
Werner Camano 230cm
bigdood
  • poormansheli
Some cheapie Aquabound (I think?  Maybe Carlisle?) plastic/metal paddle that came with the yak.  I believe it's 240cm.
NCWflounderer
  • Date Registered: Jun 2010
BB Slice Angler- long- 240 maybe? not sure of length
I also use a Werner 2 piece (not sure what model) 2 piece, straight shaft, feathered ends, fiberglass
Yaktrap
  • Date Registered: Jul 2012
Lightning 220, from Colton, OR (now they only make WW paddles, shudda bought 2).  Then the Werner Shuna 230 is next on the stack. Many others not deserving mention.
Sponsors:
