October 28, 2026, 09:56:21 PM
Topic: Hobie questions  (Read 4688 times)
NWnoob
So I'm planning on picking up my 1st Hobie soon but I had some questions.  In looking into buying the new yak I ran across a shop that has some older model (2009-2010) brand new boats that are reduced.  My questions are how do these older models differ?  I know some people have had issues with where the mirage drive mounts and leaks, is this prior to these models or have they been fixed?  Any info would be greatly appreciated.  Thanks
2nd place 2012 Salmon SlayRide
2nd place 2013 Salmon SlayRide
1st place 2014 Salmon SlayRide
Skidplate
As far as I know, 2012 changes were:
  • reinforced scuppers
  • secondary alignment pins in the mirage drive
  • slight color change on the red / hibiscus.
  • The Revo 13 also got a  comfy handle upgrade.
I don't know of any 2013 updates, and some of the above occurred mid-year last year too.
Dray
Just thought I would share:
I have a 2011 Outback, but recently purchased a new drive.  I ended up with the new version of the drive that has the secondary alignment pins Skidplate mentioned; it fits my outback fine.  I'm just glad that the changes haven't effected how the drive fits...something that may be relevant if you're worried about replacement parts for the older models.
I really like those alignment pins; the drive drops in easier and seems more stable while mounted.
Dave
tsquared
  • Date Registered: Aug 2009
If you're looking at Adventure Islands, the newer models have a larger, sturdier rudder but Hobie has sent out the new ones as an upgrade--check to see if the shop has put them on--if not--get them to do it.
T2
IslandHoppa
  • iHoppa
One of the best upgrades was a much improved seat mounting system.
iHop
JamesC
  • 2012 Hobie Revo 13 - Gray
The newer seat mounting system is great. Also the alignment pins on the newer drive can be removed to use in an older Hobie. These are all fairly small but great imrpovements. A new Hobie also comes with a warranty, that is worth considering as well.
Sent from my DROIDX using Tapatalk 2
-Anonymous
The 2009-2010 models should be fine.  One thing to check is that the kayak has a V2 drive and the clip and go piece for attaching the drive.
Theshoeman
  • Northwest Yak Adventures
  • Date Registered: Sep 2012
Where are these At for sale? May also be in the market if the price is right .
If you're in the Portland area, Next Adventure is the place to check out Hobies.  SE 7th & Washington.  www.nextadventure.net
D rock
  • www.kayakshed.com
I would definitely stick with the V2 Mirage drive.  They are easier to insert and remove.  The new seat attachments are nice as well but not a deal breaker for me.
Which models are you interested in??
If your local shop doesn't have what you are looking for we have some 2012 demos that need new homes.
Derek
Kayak Shed
 :banjo:
Romanian Redneck
  • snoodleboob smoochy bear
Derek
Kayak Shed
 :banjo:
He's baaaaack!!
RR's Channel
- Jeff Foxworthy
D rock
  • www.kayakshed.com
Good to be back in the Pacific Northwest!!!
Come out and fish with me, Redenck!!!
 :banjo:
Derek
Romanian Redneck
 :banjo:
Derek
Done. Name the time and place. :p
RR's Channel
- Jeff Foxworthy
