November 11, 2026, 02:40:24 PM
Topic: anchor rig?  (Read 10158 times)
  • Date Registered: Sep 2007
Listen to Allan, he knows what he's talking about!
That's a great solution.  Didn't think those Cam cleat worked that way - with the line coming in at 90degrees.  Tested it on my Trolley Cam cleat and works great that way.  I can't imagin a quicker release...actually wonder if that's too easy to release? I can just see me releasing that line on accident.
"Many men go fishing all of their lives without knowing that it is not fish they are after." - Henry David Thoreau
That float will sink with the weight of the wet rope and winder and if you have to quick release, bye bye everything..
 and a quick release need to be like a half a second deal, just grab and release untying or un clipping a beener is not fast enough..
Nice pics Scott.  The only difference in mine is that I connected the clip to the burried end of my anchor line on the spool.  I have to clip it to one of the holes on my reel when retreiving my anchor line but it allows me to secure the anchor line during transport so I don't have the potential for a birdsnest forming in my trunk or garage.
When anchoring, to stop the line from spooling out of the reel, I take a bite of line and feed it thru one of the holes in the spool.  Then, I take the clip (the one connected to the burried end of my anchor line) and clip onto the bite.
I'm sure you could tie a slip knot off to that cleat.
All my knots are "slip knots"!  :D  Did you notice the overuse of Zip Ties?
Actually that's a great idea,  don't need to spend more money on cleats, and I've actually used that cleat for some other things that have been handy already.  Now, just need to get a bigger float.
Just realized I totally hijacked Carls original post - hope this discussion helped Carl. :icon_pirat:
Those winders are nice huh? Thanks Brian. I didn't look that close at Brians at Willamette, but i thought it would be alot bigger then it actually is. It's pretty compact and holds quite a bit of rope. Great find.
I also abondoned my little spool of line in those pictures and went with an electric code spool like Brian and Spot are using (This was my 5th try at a spool - think I finally got it).
Geez this is hard to say without a picture.  Let me know if you need one.
If anyone has an extra one of these spools, I'd be happy to swap you for a beverage or two. I'm sure I'll be working on the anchor soon enough.
Jay
I don't have an extra cord winder, but you can get them at Lowe's for about $5-$7.
Take a look at Ace Hardware too.  I found one that's a little smaller in diameter but easily holds 300ft. of line.
I removed the "feet" from mine with a saw and file.  They got in the way when winding.
I knew i forgot something...i was gonna do that too. I found mine at true value hardware
HUNTINHICK
  • Date Registered: Aug 2007
Scott,
I am glad you hijacked this one,  you got many of the unasked questions I have been pondering about the anchor rig answered!  COSSBAYYACKER thanks for the web site with the RIVETS and other parts.  I am going to be burning up some serious WAF points between that and the AOTY sign up.
Carl
« Last Edit: April 11, 2008, 07:52:41 AM by HUNTINHICK »
I got a baggy full of those expando rivets from Captain Dick's.  I have a few extras if someone wants me to send them some.
HUNTINHICK
Hey you all,
I believe I should go with the stainless padeyes instead of the nylon do you agree or disagree?   :-\
thanks
carl
Hey you all,
thanks
carl
I agree 100%, never have to worry about breakage that way..
Hey you all,
thanks
carl
Pretty much a preference question if you ask me. I've never seen any problems with either. If you really wanted to get into a discussion about them I think a weaker padeye makes better sense. That way if it got under a heavy stress situation it would break and not end up ripping out and leaving jagged holes in your yak. But then again I've never seen that happen either. :D They just don't go under much stress.
