November 24, 2026, 11:09:59 AM
Topic: Looking for Ram extension  (Read 3722 times)
Tried to order one of these but I can't find one in stock anywhere.  Anyone know where I can find an 8 inch double socket extension for the 1 inch ball?
sherminator
I'm not sure if RAM makes them. YakAttack has a "dogbone" which is a double ball extension.
http://www.yakattack.us/Products/Products.html
Of course, I ordered one through NA awhile back and it hasn't arrived yet. (Fiskari - what's up with that anyway?)
15x tournament loser
2011 Hobie Oasis (yellow)
2014 Hobie Revo  (red)
Ram makes them, just can't find anywhere with it in stock.
Skidplate
Yep, tried to order it through gpscity and they listed it as backordered
Skidplate
Hmm... I'm stumped. I can't even find it on the RAM site.
I would probably send RAM the part number (RAP-B-201-V8U) via email and buy it directly from them. Or try to give them a call.
They're a Seattle company aren't they? Are you close enough to stop by and look around? (sounds like fun IMO)
National Products Incorporated Corporate Headquarters
8410 Dallas Avenue South
Seattle, WA 98108
USA
1-206-763-8361/1-800-497-7479
Skidplate
*lightbulb on*
Manufacturer Description
The High Strength Plastic Extended Double Socket Arm has a socket at either end to allow a 1" diameter ball accessories to be connected.
The arm consists of a 8" PVC Pipe with 1" Socket arms connected at either end. On the side of each arm, there is a tightening screw which enables the sockets to clamp firmly on a RAM 1" diameter ball. When loosening the arm side screw you are able to pivot the ball and socket connection, or disconnect the ball completely from the socket.
Each arm is 1.75" long which connects to a button to pipe socket. The total length of the arm measures approximately 13.1". You can make the arm shorter by cutting the PVC pipe.
(2) B-200-1U + (2) RAP-276U + (1) RAP-PP-1108
This will let you make the piece as long or short as you want.
*turns lightbulb off*
Lee,
I get most of my RAM and RAP parts from TheMountDepot.com.
Looks like they have the RAP-B-200-1U.....
http://www.themountdepot.com/RAP_B_200_1U_p/rap-b-200-1u.htm
and the RAP-276U.....
http://www.themountdepot.com/SearchResults.asp?Search=RAP-276U
....both in stock.
The PVC looks like they only have the 6" RAP-PP-1106 and 12" RAP-PP-1112 available at the moment.
You could always hack down a 12" one to whatever you really need.
http://www.themountdepot.com/RAP_PP_1112_p/rap-pp-1112.htm
Great ideas guys.  I'll either do that option or the dog bone option.
