November 06, 2026, 01:37:04 PM
Topic: Old fashion downrigger  (Read 3077 times)
I inherited this rod from my brother in law (meningitis took his life at 47' an amazing, healthy person -- freak infection ). It looks like a down rigger pole.  It was loaded with wire line.  One rotation is about a foot of line. I was thinking I could use this instead of a scotty lake troller. I would change out the wire to an 80lb braid and just run the line through the first roller/eye (to keep the down rigger ball close to the hull of my Hobie Outback and reduce pressure on the rod holder) I figured I could bungee the pole into one of the Hobie pole holders and setup a down rigger system.  Not sure what side and whether to use the fore or aft locations.  Nutty or doable..that is the question.
1st place, 1st bi-annual Humpy Classic
"May the fish be always in your favor."
THEFILTHYOAR
  • Date Registered: Apr 2013
I did this setup with one of my broken halibut rods. I used to troll kokanee at lake.atevens, it.worked pretty well. But it was.not easy to pop off the down rigger clip.
