November 07, 2026, 08:54:59 AM
Topic: Lowrance transducer cable pass thru seal options?  (Read 3103 times)
BennettOZ
  • Malibu Pro Explorer
Lowrance transducer cable issues. Ok I measures the connector that attaches to the FF and it's 7/8" so I need a pass thru style water tight seal. I looked at the clam style. Rubber corks will work but I am not sure oh it will look. Any opinions?
The Hobie through hull wiring kit work really well.  I also like tension relief fittings.  Just make sure you get one that fits over the plug and use electrical or self vulcanizing tape to build up around the wires.
crabbycabby
  • Date Registered: Jun 2013
Hobie through hull wiring kit.  drill a 1 inch hole, then use the kit to match your transducer cable size.
Native Slayer 13 propel
Malibu Stealth 14
langcod
http://www.kayakshed.com/hobie-kayak-gear/thru-hull-wiring-kit
This is the same port that is installed on the 2014 Hobie models that have the Lowrance transducer pockets.
2015 ORC 3rd Place Winner
Skidplate
Like everyone else mentioned, the hobie one is definitely the best kit.
BennettOZ
Thanks everyone. I had not see the hobie one yet.
