November 07, 2026, 08:56:29 AM
Topic: Marine goop removal  (Read 4715 times)
FireFly
Not sure if there is any easy way around removing marine goop, as in when you want to switch out a transducer in the hull.
It took me a pain staking amlost 2 hours with a utility knife, pocket knife, putty knife and hammer to remove my exisisting transducer without damaging it. I am now concerned about my Outback when I do decide to remove/relocate/replace it, I was a total newb and can certainly say I overkilled the goop when I installed the transducer and puck originally.
Ideas......
Red Hobie Outback
2019 AOTD 5th place
  • Chris
Haha! I feel your pain. My transducer did not want to come out for anything. I eventually got mine free. I didn't use any tools though. Just my bare hands and a little elbow grease.
8th Place 2014 AOTD
1st Place 2013 AOTD
Sponsorship and Support:
Waxer's Surf Shop
Hobie Fishing Team
Lancer Jigs
Pro-Cure Scents
Merz
  • Date Registered: Sep 2010
Ive had to do it twice now. I use a thin putty knife to get the edges up, then grab it with some pliers and pull as hard as I can. Takes me about 5 minutes. You may have used more goop than I did though.
-Evan
1st 2016 AOTY
1st 2018 SBAOTD
1st 2019 BCS
1st 2022 SBAOTD
1st 2023 BCS
1st 2023 SBAOTD
I've never had any problems using a WIDE flathead screwdriver and popping it off like an abalone.
I've never had an issue removing Marine Goop either.  Narrow chisel or flat screw driver. The first time I just grabbed the foam puck and pulled - the Goop liked the foam more than the polyethylene.  Once you get it started it seems to peel off pretty easily.  I've done my transducer at least three times, experimenting.
Was it REAL Marine Goop?
FireFly
I'm starting to wonder that myself.
Red Hobie Outback
2019 AOTD 5th place
