November 23, 2026, 04:24:13 AM
Topic: homemade trough measure device for .99  (Read 3792 times)
yaktastic
  • shut up and let me fish.
All from scraps and plastic gutter.true value yard stick .99.
4th place 2017 TBKD Rockfish.
alpalmer
a ruler that long would be too optimistic for my fishing ability  :D
Very creative and no worries if it is claimed by the sea.  Just make another.  Nice!
--Edward Abbey--
In some kayaks, the footwell of the kayak can serve as a measuring trough for fish, if you glue a measuring tape to the side or bottom of the footwell.  Just lift up your foot, drop the fish in the footwell, slide the fish forward until its nose touches the end of the footwell, and measure it.  Berkely makes self-adhesive measuring tapes which could be used for this purpose.  Since the end of most footwells isn't perfectly flat or positioned at a perfect right angle to the bottom of the footwell, this measuring system wouldn't be as accurate as a commercial "Hog Trough" or a measuring trough like yakstatic's.  You'd need to estimate where a fish's nose would come to rest at the bow end of the footwell before positioning the measuring tape.  If you wanted to be more accurate, you could add a more accurate right-angle plate to the bow end of the footwell.  In some kayaks, foot braces would prevent you from sliding large fish all the way forward.  And you could only measure fish as long as the distance between the bow end of the footwell and the front of your kayak seat.
If you're concerned about losing your measuring trough overboard, you can glue closed cell foam to the back of it so it'll float.
« Last Edit: March 12, 2014, 10:59:29 AM by pmmpete »
  • Chris
Looks good to me!
8th Place 2014 AOTD
1st Place 2013 AOTD
Sponsorship and Support:
Waxer's Surf Shop
Hobie Fishing Team
Lancer Jigs
Pro-Cure Scents
yaktastic
Idk how that would work with my rudder peddles
In Hobie pedal kayaks, the area under your legs is not at all suitable for my footwell fish measuring trough idea.  In some other kayaks, it should work pretty well.
Michole
  • my blog
"If people don't occasionally walk away from you shaking their heads, you're doing something wrong."  John Gierach
Ben Guss
  • Date Registered: Jul 2010
the rough metal edges will be hard on the fish if playing c&r...
yaktastic
Its plastic
