November 22, 2026, 08:34:45 PM
[Today at 05:32:50 PM]
Poll
what is your prefered way?
foam puck or duct seal, add water
foam puck with ducer (marine goop)gooped in
ducer gooped directly to hull
sidearm, like the liberator
other
Topic: transducer install  (Read 3373 times)
dampainter
was using duct seal but just switched to the foam puck/water, have yet to try and was curious what others are doing.
DWB123
  • Date Registered: Aug 2013
I'm cheap and relatively crafty, but mostly just cheap.
My system:
Approx 5"x5" cutting board base with slot cut in it in it that tightly fits a 1"x12" piece of metal (taken from the retractable keyboard track from an old desk), to which i've tightly bolted in the transducer on the bottom. Using a velcro strap I secure this (removable) cutting board base to an identically-sized cutting board base that's permanently fastened to my slide-track system. Easy on, easy off, and the velcro's strong enough to prevent any wiggling or movement on the water.
Transducer is directly in the water, and the whole set-up cost less than $3.
Post a picture, DWB123!  A picture is worth a thousand words.
Could "scupper mounted transducer" be added to the poll as an option?  That would include the scupper pocket on Tridents, and the covered scupper pocket on recent model Hobies.  I have one of each of those.
« Last Edit: May 14, 2014, 10:28:32 PM by pmmpete »
WayneWhit
  • OK Trident 13, OK Prowler 11
  • Date Registered: Oct 2009
Through the hull in the scupper works great.
My system:
Yes, please post pics of this.
dampainter
thats it 10? people on nwka have fish finders? is it that hard to do the poll?
Nearly everyone I know uses foam puck. The subject has nearly been beaten to death in the past , otherwise you'd get more feedback. Some guys use a transducer arm but I'd say 9/10 of the guys I fish with use a puck. It's the quickest and generally returns the best results for the least install time.ive tried the puck vs directly in the water and can't notice a difference. It's also one less thing to break on a surf landing.
The Nothing
  • De nihilo nihil
  • De nihilo nihil
  • YakFish@IOL
another for scupper mount. all Jackson boats are also setup for this
~Isaac
Blog 'YakFish
