November 07, 2026, 08:22:20 PM
Topic: Shark hook method?  (Read 4957 times)
Shark hook method? Can someone explain that to a guy that has never landed a big fish on a kayak as I'm sure hauling one on board with a gaff , at least on a kayak don't seam like a good idea. And for the experienced kayakers how does one rig the hook. In laymans terms please I'm an ex garbage man not a professor.
Only needed for halibut.
Fish bonker with a large stainless steel hook attached to it.  Short length of cord attached to buoy.
Definitely going to try that method.  I was afraid the hook wouldn't penetrate.  We will see...I hope!
Lee that's a big fish. So non butts net um and knok um?
I pretty much just use the plastic lip gripper for all my big fish.
Occasionally a little wood shampoo is needed, so the bonker is on hand.
I have only gaffed a few fish and a octopus, and don't usually take it with me much on the water anymore.
A lip gripper and a bonker is about all you'll need for most of the fish we get offshore.
Salmon however would be better handled with a net though.
Here is my use of a shark hook on a smaller fish that I did need the buoy for. The rope allows you to hang onto a fish while it tires at the side of the boat.
« Last Edit: June 22, 2014, 07:51:22 AM by Fungunnin »
I carry a straight gaff (aka Hawaiian spear gaff). I haven't had to use it yet but check it out (Google).
Kenai_guy
nets are more a pain in the butt than a help.  I've played around with several ideas, and my current setup seems to work the best for me with buts.
All I carry is pliers (hook removal), lip grippers (pulling in the little ones & handling once on board), and a modified harpoon (for securing those greater than about 25 lbs).
Now many of you say...."geez, why do you harpoon the little ones?".  My answer:  So I know what the #3!! I'm doing once I do get that fish over 50 lbs and actually need the harpoon.  That's what works for me.
9th place 2014 ORC
  • Date Registered: Feb 2009
Good point!
What are people wrapping the cord to the hook with? Is that electrical tape or shrink tubing?
Fred "True" Trujillo
I used electrical tape because I didn't have any shrink tubing laying around. I also ran a piece of stiff metal up the center of the splice to give it a little more length.
Yeah, I'm looking at some type of handle that's a little thicker than just the shank of the hook to hold on to. I may need to work a dowel in there or something...
Most guys add a short fish bonker 12" or so to the hook
I have a ~12" handle, made from the end of a broken shovel handle, on mine.  I haven't used it yet and am considering shortening it.  I'm concerned with what will happen when I put a 12" billy club the mouth of a really big, really pissed off fish.  I'd imagine it could do a bit of damage to me or my yak.
Personally I don't think the wood handle is necessary. Most halibut I've caught are pretty chill at the surface until you stick them.
Has anyone ever lost a fish once they had it gaffed with a shark hook??  I lose fish with big hooks all the time...when its attached to my line.  Is the shark hook pretty much a sure thing once you have it in the halibut?
I'm really terrified about what a 50 pound halibut could do while I was attached to it in anyways.  As is, I have already dropped my boca grips a few times (thankfully I have small buoys attached to it)  when I had a 25 pound fish secured with it and it started thrashing.
After my harpoon bounced off the spine of a decent halibut, but apparently stunned it to the point where it was completely dormant, I am reconsidering something like a small .22 but firearms, me, and a kayak doesn't sound like a good mix!
