November 22, 2026, 06:39:56 PM
[Today at 05:32:50 PM]
Topic: Help with an idea  (Read 3542 times)
newprincipal
  • Date Registered: Sep 2013
I have a great idea to build an internal storage system for my trident using nylon eye-pads and shock cord.  However, the design dictates that I use an adhesive on the eye-pads.  Marine good says it's not recommended for polyethelene.  Ideas?  What is a good adhesive for polyethelene?
Basically, I am making an internal net system to anchor things to the hull.
Check out eplastics on line they have a wide selection of plastic glues. http://www.eplastics.com/Multipurpose-Glue
Why not use pop rivets?
I'm going to guess he doesn't want holes below the waterline ...
Ha!   ::)  I guess what I was picturing didn't require making holes below the waterline....
newprincipal
I can't seem to find a good adhesive for poly...I think that's the nature of poly...I will keep looking.
Dray
I'd look at 3M's  line of epoxy, I thinks it's called Scotch-Weld.
Also, they have a pretty strong/durable double sided foam like tape that might work.  This isn't exactly what I'm talking about, but something like this:
http://www.uline.com/BL_6083/3M-CT-3010-Outdoor-Carpet-Tape
Just a thought
Dave
Breachers tape would most likely work, but is expensive ($57 for a 2" by 50' roll).
