November 23, 2026, 02:00:55 AM
Topic: Lowrance HDS 7  (Read 2989 times)
Memkis
  • Date Registered: Jul 2014
Anyone have experience with the HDS 7 Touch? I mounted the transducer in my Hobie where they've put the transducer compartment but I'm not sure exactly where to mount the LSS 2 module so that it doesn't interfere with the transducer. Since I am likely using rivets I want to get it right the first time. Thanks
  • Date Registered: Oct 2009
From what I read on line, the LSS 2 module is an interface "brain" and needs to be mounted where you can see the lights if a problem exists.....see the following video.....
So, the LSS 2 box location need some flexibility and not to worry about the transducer since the signal is away from the hull.
